RB-1080 power cord options
  • JonJeffman
    • Apr 2009
    • 24
    Hi there,
    So my RB-1080 got delivered this weekend, but the seller forgot to put the power cord in the box. So while I wait for him to send me the stock cord I was just wondering if I could use a power cord from my PC to run the amp? Looks like the same socket to me.
    I'm not looking to open Pandora's box about the effects of the mains cable on the sound of the amp, I just am anxious to hook this baby up and take a listen and don't want to start any fires or blow fuses in the process. I looked up IEC connector in Wikipedia and it says most PC sockets are rated for 10 Amps, but the fuse on the 1080 is 12A, so I don't know if I'll pull too much current through the power cord.
  • mjb
    • 1485
    Yes, its the same connector, a pc power cable will work fine.
    - Mike
    Main System:
    B&W 802D, HTM2D, SCMS
    • DL86
      • 271
      Yes, any standard IEC power plug will do the job fine.
      • scottvalentin
        First time amp build - Abletec buyout power supply, Sure IRS2092 board
        by scottvalentin
        First time post here, but I feel like I know lots of you just from reading many of the threads here!
        For background, last year I built an LCR set of Overnight Sensations (MTM ones) that I ordered from Meniscus. I have read the PE Forums and almost every thread here at Mission Possible...
        24 March 2016, 14:05 Thursday
      • wa5655
        Upgraded Power Cord for RSP-1098?
        by wa5655
        Hi, all.
        I am ready to upgrade the power cord for my RSP1098. However, most after market cord has a 3 vertical pin IEC connector on the end goes into the RSP1098. The OEM cord only have vertical 2 pins. (not C7-rounded)
        Any ideas where to find an adaptor for it? I have searched...
        28 January 2004, 01:10 Wednesday
      • ti33er
        ROTEL 1066/1075 - APC 450 UPS Compatibility?
        by ti33er
        Hi again,
        My work is throwing out some perfectly good APC UPSs, and wonder if any of you delightful fellows know whether or not they would be able to support my ROTEL 1066/1075 units? (and if they are worth using anyway?)
        The specs are as follows: (I live in the UK and...
        07 May 2004, 07:10 Friday
      • Greg K
        SUPER CHEAP power cord upgrade
        by Greg K
        Hey guys,I've been following the "power cord" thread here, and find it quite interesting.On another message board I read about a really cheap PC availabe to sorta"test the water" on power cord upgrades.This cord is made by Volex,2 meter,14 gauge shielded,OD of about 9mm.Lots of good...
        11 October 2003, 08:36 Saturday
      • clm811
        Premium-grade power cord
        by clm811
        Upgraded power cord{AWG16x3C Shielded w/IEC plug} sold in bulk, (identical to that supplied by both Denon and Parasound with their high-end components) It is an audible upgrade to the standard "computer" cords supplied with most components. Marinco and Wattgate plugs are available through...
        07 November 2002, 19:12 Thursday
