I'm new here
I just bought a second hand RSX 1056 and a RDV 1092. Very thrilled with it!The remote control from the DVD works fine but the RR 1050 that goes with the 1056 does not work any longer. In first instance the light of the display was on and I was able to turn on the dvd, then the buttons no longer reacted. After resetting, it stopped working completely.
I've put in new batteries and tried to reset it but the only thing I get in the display is 'waiting'. I've waited for 24 hours but nothing happens
Has anyone had the same problem? Is there a way to fix it or do I have to buy a new one?
best regards,
Balou
I'm new here
best regards,
Balou
