HD-DVD problem with RSP-1068
  • Dingaling2004
    • Jun 2007
    • 18
    Hi there guys, thought there may be some collective wisdom out there with a problem. I have the following AV gear:
    Rotel RSP-1068 pre-amp processor
    Rotel RMB-1077 7 channel digital Icepower amplifier
    Toshiba HD-A1 HD-DVD player
    Infocus X2 projector (yep, time to upgrade!)
    I have connected my HDA1 through my Rotel pre-amp and find that it makes the projector unstable. I keep getting blue screens saying 'setting up picture' when connected through the processor. When I direct path the HD-A1 to the projector, I don't have this problem. It was my belief that the RSP-1068 was upgraded to 100mhz bandwidth for HD use, but it does introduce instability. Anyone else have this problem?
  • Kevin D
    • 4601
    Did you remember to turn the PROGRESSIVE setting on for the input the HD-A1 is connected to? It's under the display setting in the menu.
    Without it turned on you will loose sync every time the 1068 tries to display any information (volume adjustments, sound change, etc.)
    Kevin D.
    • Dingaling2004
      • Jun 2007
      • 18
      Thank you very much. I will try this and let you know how I go. After tring it both ways, I did find that the image is slightly softer through the pre-amp (or is that beacuse I am using a geriatric 852x480 SD projector???)
      Thanks again and I really appreciate having such a great forum to support owners of this awesome product. By the way, love the picture of your install. Gorgeous work! :T
      • Kevin D
        • 4601
        Thanks for the compliments! In theory there should be no difference running through the 1068 or not. Even when it doesn't lose sync, having the progressive setting turned off could degrade the signal.
        Kevin D.
        • frootie
          projector problem?
          by frootie
          I recently received a Sharp XV-S90U LCD projector and Sharp motorized screen (about 7' wide) from a relative for free because he was upgrading his system. I know the projector is old (8 yrs. or so) but it only has around 200 hrs. on it. (He has a lot of toys he never really uses). The picture looks...
          19 May 2004, 09:31 Wednesday
        • webcat1
          Lamp/Projector problem
          by webcat1
          Can any one help please. I have an infocus 4805 and when projecting there is a brownish line down the right side. Is this a lamp problem. I have taken the lamp out and cleaned as per instructions but this has not helped. Im lost as to what to do.
          02 August 2007, 07:03 Thursday
        • wywong
          RSP1068 problem
          by wywong
          Hi, my 4 yrs old rotel rsp1068/rmb1075 suddenly drop the right front channel yesterday. I switch the RSP1068 pre-out right and left front connection and the problem will move from right to left. So it definitely mean it is not a cable or rmb1075 amp issue. I try power cycle, unplug the power and wait,...
          20 December 2009, 11:31 Sunday
        • howburger
          Grungy midrange with RSP1068
          by howburger
          Hello everybody:
          I've got a system that consists of the following:
          1. RSP1068 Processor
          2. RMB1095 Amp.
          3. Toshiba DVD/DVD Audio Player
          4. Yamaha CD Player
          5. Main Speakers - Dayton D3 MTM DIY
          6 Infinite Baffle Sub with 4 Atlas 15's powered...
          02 February 2006, 17:37 Thursday
        • torgelow2005
          high frequency noise / hiss, RSP1068
          by torgelow2005
          I'm using the RSO 1068 + RMB 1075 and I'm not satisfied with the noise behavior!
          I'm not talking about white or pink noise from the power amp but about a high frequency signal (kHz range, like
          tinnitus) mainly from the rear speaker.
          I only hear this noise when...
          02 September 2005, 13:14 Friday
