Rotel 1098 listening issues?!?!? pls help
  • nadroj29
    • Nov 2006
    • 4
    I just bought the rotel 1098 surround sound processor. And love it. Got it connected the first night and replaced my previous reciever. But when i listen to cd's through pcm digital via a toslink fiber optic, my processor sais its producing a sub output but my subs wont come on. however while watching dvd's on my denon dvd player, my sub works fine. So to say the least im confused. While my 1098 is saying i should be getting sub signal with cd's i get none! but sacd's and dvd i get sub output?!? any advice would be so appreciated. id love to get the full experience of digital cd listening with my subs.
  • Kevin D
    • 4601
    How do you have your speakers setup? You will have to have the speakers set to small to get output in stereo, even though the OSD shows a sub enabled.
    Kevin D.
    • nadroj29
      • Nov 2006
      • 4
      thanks but.....
      now i do get sound out of my subs, however it sounds like its altered the bass output and or frenquencies is there any solution to this, i cant seem to adjust this in its menu....
      • chinets
        • 855
        Go to the Sub set up and fiddle there In your OSD menue!!! You can also change crossovers and Lower the Db of your sub for every source you use In the OSD!! Check the Sub set up, Check speakers crossovers and play with the conture!!
        Give us feed back please?? Interested to know if you have solved your problem!
        Cheers
        • SwainDtV
          Issues regarding SSP-800 sub output
          by SwainDtV
          I’m posting this in HTGuide and AVS forum.
          I have a Velodyne powered sub connected to my SSP-800 with XRL cable. When I press mute or when a digital input (HDMI/coax) is interrupted e.g. movie pause, transition between menu and movie, I get one or more thumps from...
          07 September 2010, 07:31 Tuesday
        • Jason Brown
          RSP-1098 2CH sub output.
          by Jason Brown
          While playing CDs and switching between bypass and stereo using the "2CH' button on the remote, I get no output from my subwoofer when in stereo mode. I can't figure out why this is. The sub box is highlighted on the display and the sub itself works fine in Dolby Digital from the DVD player, but...
          23 February 2004, 23:44 Monday
        • Aussie Geoff
          RSP 1098 Wish List V2.0
          by Aussie Geoff
        • EAmin
          Two Subs with RSP1098
          by EAmin
          I'm running two DD-15 subs with my 1098. I hear both subs when I'm playing movies OR watching HD coming in with a Dolby Digital signal. But if I'm watching standard defn TV, playing my Playstation in ProLogic IIx I only here my first sub --- not both. When I do my test tones for the sub, I hear both....
          12 December 2005, 10:52 Monday
        • ro9397
          Sub: sonotube, siting, EQ, delay?
          by ro9397
          Questions concern siting & enclosure material for a custom sub for a very high-end music reproduction system. Sub source is a mono signal from a proprietary pure-analog processor. Will start w/ one sub; depending on results may add a second sub.
          Room Dimensions & Volume
          03 February 2007, 01:28 Saturday
