Questions concern siting & enclosure material for a custom sub for a very high-end music reproduction system. Sub source is a mono signal from a proprietary pure-analog processor. Will start w/ one sub; depending on results may add a second sub.
Approximately 26.6’ x 16.6’ x 8’, 3575 cu ft; unknown whether speakers are going on 27’ or 17’ wall.
Will be actively &/or mechanically high-pass filtered @ 70 Hz.
Internal displacement approximately 4.4 cu ft
Reflex-loaded
Active heavy duty 15”
15” passive radiator, tunable mass loading
1000 WRMS amp, active low-pass XO, single-band parametric EQ
Sonotube (cylinder-shaped treated-pulp cement former) is the proposed enclosure material because it is light, it’s affordable, it’s easy to finish, it has a relatively small footprint, & it fits in a corner or freestanding.
The active 15 would fire upward toward the ceiling, the PR15 would fire downward & spaced appropriately off the floor a few inches. (The vertical orientation of two subs can be inverted, i.e. one active fires up/PR down while the other sub does the opposite; would likely smooth room modes.)
Below 60 Hz how much will the ST’s “organ pipe” resonance (diameter repeats for entire length) contribute to one-note bass?
What about stiffness & anti-resonant qualities of the pulp? It could be internally lined w/ cork, Black Hole, &/or borosilicate.
What is recommended method to attach the driver baffles to the ST? Will Liquid Nails properly secure the outer perimeter of the baffles to the inner walls of the ST?
Is cloth or veneer best to finish the appearance of ST?
Other comments regarding ST?
Corner siting increases bass output but can decrease smoothness & delay sub output relative to the main channels.
In my previous room a Sunfire sub was crossed similar to the proposed frequency. The sub was sited in a front wall corner R of & behind the R main speaker. No delay was applied to the main channels to time-align the sub & mains. There were no audible timing problems. Others predict time alignment problems. What say members?
The above Sunfire sub had 5-bands of digital automated EQ. The proposed sub will have single-band parametric eq. In the room described below 60 Hz, will single-band parametric EQ be enough to smooth the corner-loaded response?
Thanks for your consideration!
Room Dimensions & Volume
Main Speakers
Proposed Sub
Reflex-loaded
Sonotube Enclosure
EQ & Delay vs. Room Siting?
