I have noticed a lot of people on this board use these drivers, so I thought I would post here about my project (I'm sure some of you saw it on diyaudio). Here is the first revision:
It uses Dayton HF 12, Peerless 830875, Seas 27 TDFC.
For the second revision:
I caught a couple of errors, one is I should use a 18db/oct electronic crossover on the tweeter, as it is already rolling off at 6db/oct. In the new version I plan to upgrade to the peerless exclusive 7", and crossover to the daytons at about 160Hz LR4 instead of 85Hz. I also am planning on implementing baffle step correction, I'm still uncertain whether it sounds better with these drivers (been playing with it with eq), but I'll put it in the circuit this time. I'm using an active analog crossover. I also think I will throw in a Linkwitz transform down to 25 Hz, and rumble filter at 10Hz.
My goal with these speakers is to play loud clean (or soft clean). I'm not sure if stereo 12's is enough to get high spl (100dB) clean, may I need four at one point (can't afford the extra amplification now). Any comments on the new design?
