RSX-1067 set up problem
  • padillon
    • 10
    I own the new Rotel RSX-1067. I have found that the set up described in the owners manual doesn't work properly. I discovered by accident that when you first turn on the receiver, you get the on screen display which can get you into the system set up, but only if you move quickly.
    I installed the software upgrade last weekend, and while the PL(x) sounds great, it has not solved the set up problem.
    Has anyone experienced this, or more importantly solved the problem?
  • Azeke
    • Mar 2003
    • 2123
    Padillon,
    Just a quick thought, have you tried the Remote to access the menu to see if that works. Press AUD, and the menu function.
    Azekie
    • padillon
      • 10
      Azeke,
      Thanks for your reply. I have tried the remote to enter the setup menu as described in the manual. I even downloaded the ccf file for the 1067 and programmed all the functions into my MX-700 remote, but still no good. I have since discovered that the remote will not allow me to make temporary level adjustments to the center,front,surround and sub the way it's explained. I have found the manual somewhat difficult to follow sometimes, but I have read it cover to cover several times looking for any clues to these anomalies and still can't figure it out. My dealer is supposed to contact Rotel to see if they can help. If they do, I'll post the results, how ever embarrassing they may be.
      • vsarathy
        Problem with the EXT Button Rotel Remote
        by vsarathy
        Hello All:
        I use a Denon DVD-1600 player for DVD-Audio playback in conjunction with Rotel-1098 processor. The problem that I have is actually more with the Rotel remote controller.
        According to the manual, pressing down and holding any of the input buttons on the top row...
        08 December 2004, 17:48 Wednesday
      • gruss
        Why you should never read the manual!
        by gruss
        Other day the new 1067 was acting up, would respond extremely slow to the remote, wouldnt change inputs etc etc.
        The night before while leafing through the manual I spied that the 1067 can supposedly handle the 192k bitstream from the DVD player so I changed that setting on the DVD player and...
        19 September 2007, 19:23 Wednesday
      • john4618
        How do you program the C2 remote to display the Setup Main Menu ???
        by john4618
        Thanks to my existing MX-700 remote it was almost painless to program the new C2 MX-700 remote. The only thing I can not get to work is how to activate/display the Setup Main Menu on the TV from the remote. I’ve tried the MENU option many times in the IR CODE drop down box but that option performs...
        07 April 2004, 02:36 Wednesday
      • Dennis92
        HELP! rsp 1066 Installation Stalling: Can't get past the status menu!
        by Dennis92
        Well, I'm off to a bad start with highly anticipated 1066, can't get past the 'status menu' in installation. It states that I need to push the 'ent'-button (enter) but all that happens when I push that button is the message 'EQ cinema on'. When I push it again it says 'EQ cinema off'....
        05 September 2004, 13:00 Sunday
      • deaconblues
        RR-1050 Remote - Help and Advice Please!
        by deaconblues
        I spent part of the day programming the Rotel RR-1050 and now I'm stuck with a remote that won't give me the on screen display that I was able to view yesterday! I've tried preloading after clearing both AUD and Video 1. I've cleared all of the commands that I've entered. I've even installed new batteries!...
        23 November 2006, 18:45 Thursday
