My RDV 1060 had firmware 2.0.8 and I know this one has several problems with DVD-Audio discs and progressive scan.
I assume the latest software available now is 2.1.2
I have a few questions to owners with that software installed:
1) How is the Audio setup menu ?
Do you have to specify the output format ( analog or digital ) for Cd,DVD,mp3,Mpeg and VCD separately ?
2) Do you still have audio on both your analog as digital outputs simultaniously ( + on the scart as well ) ?
I'm asking as I have the European version of the RDV 1060 and it was upgraded to a Dutch version of the software (436 ) and I have all these new extra menu's as mentioned in 1.
Before the upgrade I had only minor problems, now I don't have any audio anymore to my analog outputs when I select digital in the OSD audio menu for each format (Cd,DVD,MP3,...).
Neither do I have audio on the scart or I have to go to the OSD Audio setup menu of the player every time to change it to analog.
With the old 2.0.8 firmware, I always had audio on all outputs at the same time.
Another problem is that I can't skip through the menu's anymore like the copyright warnings, other publicity, ... on DVD's. I have to watch all this junk, before I could just skip it all with the "Next" button and go to the movie directly.
The goto button is disabled in several DVD's where it worked well before the upgrade.
Also, the last memo function is gone, so resuming a movie is out of the question as well.
Are users with software 2.1.2 having the same problems I describe or not ?
I hope I receive some feedback here as I'm deparate :-(
Nico
Nico
