I'm a new 1056 owner and have been doing some experimenting with the receiver's crossover settings. I'm a bit curious as to how others have theirs set. I am running B&W 602s3s all around with a M&K MX-125 sub. This is a 5.1 setup and all of my speakers are set to small. I am using high-quality custom silver speaker cables. Obviously, with the 1056, I am unable to bi-wire the front speakers. Part of my concern lies in the fact that I seem to get a much more robust sound with the crossover set at 100Hz. This seems like to high a setting to me. Whenever I switch over to 80Hz, I feel like I'm losing a significant amount of bass. I'm concerned that setting the crossover at 100Hz will under-utilize the bass performance of the 602s. Even though 100Hz seems to give me the best performance I've yet found, I'm still not quite satisfied with the overall dynamics of the system. I had a much better bass/treble/mid-range balance with my previous Pioneer Elite receiver in this same room. Would anyone recommend a particular setup for this kind of system? I think part of my problem might be that my room is irregularly shaped with a high, sloped ceiling and hardwood floors. I have a large area rug that hopefully provides some dampening for the sound and, of course, all the standard furniture to help in this manner.
Any advice would be much appreciated!
-Ben
-Ben
