A 1098 question regarding loss of sound ????
  • chinets
    • 855
    Hi Ya'll,
    My 1098 Rotel Processor has my 3 satellite decoders on Video 3, 4 and 5.
    On Video 4 ONLY as the rest act perfect In 5 channel or PLC 2 or dts neo 6, the sound of the front Left speaker and Back Left speaker and Center work but not the Right front or rear work during these sound choices especially In 5 Channel and this has been acting up lately ,and sometimes it works ,and sometimes it doesn't.
    If I put the choice of Music 1, 2, 3 it works so really it is not the reception as one would think ,receiving the satellite image and sound in Mono is not possible beacuse then how come I can get the sound processed in the right front and right backwhen it is in Music 1, 2, or 3 mode???
    Very bizzare??? Does anyone have a soution here or has this ever happened to anyone?? Can this be a faulty 1098 as the rest of the outputs work in 5 channel and all seems good????
    Can anyone urgently help me please!!
    Chinets
  • Kevin D
    • 4601
    Just did some testing. If I don't have a right cable plugged in, 5ch stereo will only play out of the left speakers (front and rear).
    So, that means the 1098 is not getting a signal for the right. There's three possibilities; sat unit, cable, or 1098. If you swap the cables going into video 3 and video 4 an the problem moves to video 3, you have a bad sat or cable. If it stays on video 4 you have a bad input on the 1098. Nice thing is they can just send you an analog input board and you can swap it out.
    Given that it sometimes works, it might just be a loose cable and swapping video 3 & 4 might make the problem go away.
    Kevin D.
    • chinets
      • 855
      Kevin D,
      Thanks for your input and your help. I will check this all out at home as you stated above and let you know what the out come was.
      I appreciate your kind help and attention and I believe you are 100% right.
      Will answer you as soon as this problem is solved.
      Thanks pal,
      Chinets
      • chinets
        • 855
        Kevin D,
        You are awsome!!!WOW!! amazing as you detected the problem surgicaly.
        Yup!!!!! It was the cables and all fixed now!!perfect.!!
        Thanks for your kind and accurate advice..You're a genious pal!!!!!
        Do you have an electronics background??? I'm amazed!!
        Best wishes to you ,and I appreciate all your wonderful help.
        Chinets
          I think it's from all of us just playing around with stuff we find out solutions to various problems. Kevin definitely knows his stuff though! Good job!
          Glad to hear it's working chinets!
          • Kevin D
            • 4601
            Glad to hear you found the problem.
            I am an AV installer/designer by trade, but my education is actually in international business (go figure...).
            Kevin D.
            • chinets
              • 855
              Well great Job Kevin D, and thanks again for your kind advice.
              Wish I could understand electronics and stuff!!!
              Thanks you guys (PewterTa and Kevin D) for your good wishes,
              Chinets
              • skipm
                1098 Video Setup Questions
                by skipm
                Since this is the first receiver/processor that I've owned with more than 2 component video inputs I wanted to check with the other 1098 owners in the group to make sure I was reading the setup information correctly. You can connect 5 video sources, labeled Video 1 thru 5. You have 4 component video...
                11 August 2003, 14:09 Monday
              • Swilliams97
                1098 video cutting out
                by Swilliams97
                I have a new 1098 with both DVD and Scientific Atlanta cable box connected with Comp cables and using video switching. Time Warner Cable suggested setting cable box for 1080i output only and when the 1098 was set for progressive output I got horizontal lines and distortion at the top of the screen,...
                14 August 2005, 12:38 Sunday
              • Steve B
                1098 video upconversion?
                by Steve B
                I posted this over at Home Theater Forum, but figured this was a better place. Sorry for the redundancy if any of you follow both forums!
                I just hooked up my new 1098 over the weekend. I haven't had any time yet to do any calibration and/or tweaking. I can't really comment on the 1098...
                12 January 2004, 17:07 Monday
              • jimmyp58
                1098 video setup question
                by jimmyp58
                I think I know the answer but just to be sure. I have two Sony M555ES 400 disc CD carousels. I will connect each of them to the 1098 via digital coaxial input. No problem here. The question I have is, each of them has a video out via composite that I currently connect to my HDTV; I wish to connect them...
                24 August 2003, 18:47 Sunday
              • xavierzx11
                New RSP-1098 video question. NEED HELP
                by xavierzx11
                Hi, I'm new here and I just got my new RSP-1098 yesterday! But I do have one question. I can see all my video sorces on the front of the 1098 esply for my Zen High Def STB. I have a composite video cable going from the Zen (vid1) to the 1098 (composite 2/I am using component 2 for the STB). What...
                24 August 2003, 09:48 Sunday
