RSX1055 subwoofer connection - how??
  • OakIris
    • Dec 2003
    • 80
    :? I just bought a subwoofer - a Velodyne CHT-8 (I know, not the best sub to use, but what I could afford at this time!) - and realized that the Rotel RSX1055 has no sub connections! How do I connect a sub to this receiver? The owners manual is no help, nor is the Rotel site. I did a search here, but couldn't find anything about it - guess everyone else knows what they're doing. h:
    Sorry for the newbie question...I made the assumption that the Rotel receiver had all that was necessary for connecting a 5.1 speaker system, and it probably does, but I can't figure it out.
    Help!
  • simreg
    • May 2003
    • 3
    Use the sub1 preout on the left side of the receiver. You connect it with a RCA cable.
    http://rotel.com/support/pdfs/drawings/rsx1055-bk.pdf is a drawing of the back of the 1055.
    • OakIris
      • Dec 2003
      • 80
      Well, now I really feel a bit foolish! I saw the pre-amp connections on the back of the receiver, but didn't, obviously, take note of the sub 1 & sub 2 connections. I take it I need some sort of a "Y" RCA cable - there are left & right RCA inputs on the subwoofer, only one connector on the receiver. Just trying to make sure I'm understanding.... ops:
        Twin Moderator Emeritus
        • 16706
        Double check with your sub's instruction book but you should be able to connect a single RCA line from the sub1 preout to the "left" input of the sub. That is the conventional way of connecting a mono signal to devices with stereo inputs available.
        P.S.
        No need to feel foolish That's what forums like this are here for. There's only one way to know how to do all this stuff and that's by learning from other people and asking questions. Don't be afraid if you have any more of them Now go enjoy your 1055 and the rest of your system!
        Need a new display? Questions about new display technologies? Visit RPTVs, plasmas, and other monitors @ HTguide
        • Dmantis
          M&K MX-125 Mark II Subwoofer
          by Dmantis
          What's up everyone?
          I recently aquired a used M&K sub woofer. It had a bad Phase switch which was causing it to pop. The person I got it from didn't want to get it fixed and decided to get a new woofer.
          I took this subwoofer home, fixed the Switch and decided to add it into my system...
          16 November 2013, 07:50 Saturday
        • gimpgutter
          Rx 1052 plus Subwoofer
          by gimpgutter
          Hi, this is my first post here. My dad just purchased a Rotel RX-1052 stereo receiver. He was also looking at the B&W CM4 speakers which he was VERY pleased with. His only concern was the lack of deep bass. Going from his 25 year old 12" Cerwin Vega's to these was a step in the wrong direction...
          22 February 2005, 22:31 Tuesday
        • AwArEnEsS
          Can I connect Pioneer VSX-519V-K to JL Audio E112 subwoofer?
          by AwArEnEsS
          f I buy JL Audio E112 subwoofer, can I connect it to Pioneer VSX-519V-K receiver?
          JL Audio has only unbalanced(RCA?) connections , and I am not sure which connection type
          Pioneer VSX-519V-K subwoofer pre out port use. It seems like it has RCA type connection for
          subwoofer pre...
          14 April 2015, 22:33 Tuesday
          HDMI help with AV receiver
          by audioqueso
          I'm looking to buy an AV receiver in March, but I'm kinda confused as to whether I would need HDMI.
          I was debating Marantz vs Arcam, and even though I never heard an Arcam, I was sold by others to get the Arcam. However, Arcam AVR300/350 doesn't do audio over HDMI or upconvertion of...
          16 January 2008, 03:48 Wednesday
        • ht_addict
          RCA connectors picking up interference on my amp
          by ht_addict
          Currently I'm in contact with Rotel regarding my 1095 that gives of a hum when connected to my pre/pro. The hum that the amp gives of is only present when my DVD player is connected to pre/pro via coax but not with optical. Its also present when my dvd/pre is connected by optical and I connect my sub...
          09 April 2004, 20:17 Friday
