1098 question, Need Help!
  • xavierzx11
    • 23
    Ok, I have a question. I have the Rotel 1098 (love it) as my surround processor. I am video switching all my video sources (DVD, D-VHS, HDTV Tuner, Tivo, and X-Box) through it via the Component out to my 65" RPTV. I have just ordered a Sanyo Z2 front projector (Merry X'mas to me). I plan to try the Bravo D1 player (via DVI), but I would like to have my D-VHS and HDTV Tuner hooked up to both my RPTV and PJ at the same time? Help! :?
    "Everyone has to have a hobby!"
    Twin Moderator Emeritus
    • 16706
    I'm no expert but it sounds like you'll need some sort of video distribution scheme. I'm sure someone here will know more info but until then try doing a search on here and the web for "Video Distribution". Another good place to try would be your local dealer/custom installler I'm sure they've run into situations like this and can offer some good advice. You may also be able to use a video scaler if it allows for switching and multiple active outputs plus it would have the added benefit of scaling all your sources to at least one of your displays native resolution. I don't know enough about them unfortunately to tell you for sure what would work though...sorry
    J.R.
    Need a new display? Questions about new display technologies? Visit RPTVs, plasmas, and other monitors @ HTguide
      • 27460
      This is a problem encountered more and more by people, including myself. You in fact need a video switcher. I'm not sure who's building them, but I see a wide open market opportunity there for someone to include all connection options.
      I don't know what makers such as my own Lexicon were thinking having 1 set of component outputs!
      Lex
        • 16706
        Will a video switcher allow him to watch different sources on two different displays at the same time though? If I understand what he's looking for he wants to connect his Sanyo projector via DVI and RPTV via Component cables and be able to watch any of his available sources, including different sources, on both at the same time. Ie: He could be watching his D-VHS player on his PJ while his wife watches something from the DVD player on the RPTV. Or he could have an HD Football game on in the two rooms at the same time from the same HDTV tuner for a nice beer swilling day with the boys
        J.R.
          • 16478
          The guys above are right in that if you intend on sending both a component feed from the Rotel to the projector (great choice BTW) and the TV. I decided that for me the PJ was priority one so I have my component feed running just to the projector. The wega gets an s-video feed instead. For me the convienience of not having a switcher is more important then a slight improvement in video quality for the smaller screen where its less noticable.
          • xavierzx11
            • 23
            Does anyone know a good way to video switch DVI? That way I could run the Bravo DVD player and my HD Tuner from the DVI input on the PJ.
            paul
              • 16478
              I'm not aware of any DVI switcher but I'm sure someone will be out with one soon .
              • Azeke
                • Mar 2003
                • 2123
                Paul, check this out this site, I'm not sure of the specifics on the box.
                Azeke
                • >>Angel<<
                  Rotel 1060 Video connection with 1098/Plasma.
                  by >>Angel<<
                  Dear Rotel enthousiasts,
                  Yesterday I bought a Pioneer plasma screen to complete my Rotel setup
                  After concluding all the (required) connections I found out that there's a problem displaying (progressive or not) an 1060 image on the Plasma screen.
                  I really hope...
                  19 February 2006, 06:23 Sunday
                • rosros
                  life with rsp 1068 vs 1066 vs 1098
                  by rosros
                  In feb I had a chance of comparing side by side the rsp 1098 with the rsp 1066. at the time, I was thinking about upgrading from the 1066 to the 1098. the rsp 1098 was a loaner from my rotel dealer. I had the 1098 for one week. Although the 1066 is a wonderful unit, for my usage, ultimately, it was...
                  03 June 2004, 20:09 Thursday
                • marginwalker
                  HTPC Video -> 1098 TFT Display
                  by marginwalker
                  I'd really like to be able to use my TFT to access a bare minimum of controls from my PC, I'd probably configure a desktop with a couple of shortcuts, or program a start screen with 2-4 large buttons because nothing more will be legible on a fuzzy 640x480 desktop in 16x9 stretch-o-vision. Anyone try...
                  02 September 2004, 09:24 Thursday
                • Bob
                  DVD v.s. DVHS Shootout
                  by Bob
                  Last night I had the privilage to watch an extensive demo of DVHS or D-theater (which is what it is being called) at Widescreen Reveiw's incredible reference video theater. I wish that at least one other member would have been there, not only to verify what I saw and heard but also because I am a terrible...
                  09 June 2002, 17:34 Sunday
                • Kevin P
                  Component Video Distribution Amps
                  by Kevin P
                  I'm currently using a Cable Electronics AV400COMP component AV distribution amp to send component video to both my plasma and a Lumagen scaler connected to my NEC 9PG CRT projector. The AV400COMP is adding noise to the PJ's signal and lacks a suitable S/N ratio to get proper black levels on the PJ....
                  09 January 2006, 11:07 Monday
