Problem with Rotel remote control
  • Cooldmitriy
    • 68
    Folks,
    my 2 weeks old 1056 is giving me some problems. When I want to switch between CD and Video 1 or any other source I can't do it from my remote.
    I can still switch the sources by pressing "CD", "Tape" and etc. bottons on 1056.
    I already changed the battery in the remote, but it didn't help. "On/off", "Volume up/down" work fine on the remote, but not the source selector.
    Has anyone seen anything similar ?
    Thank you ;x(
  • aphexist
    • Jan 2004
    • 158
    To select the source you want for playback you have to hold down the button for about a second. It will beep after it is selected.
    Pressing the button quickly only enables the custom controls for that device.
    • Cooldmitriy
      • 68
      Aphexist, you are the MAN. You were 100% correct, I just need to hold "CD" botton for 1 sec.
      Thanks a lot.
      • stantheman2
        Harmony remote with RSX-1056?
        by stantheman2
        I have owned the RSX-1056 for almost a year but have never liked the remote - I have to reset every time I want to use the OSD, I sometimes have to enter commands multiple times, etc. I saw the Harmony remotes (659, 688, and 880) and was intgrigued by the Internet-based programming and seeming good...
        21 March 2005, 14:35 Monday
      • deathstroke
        Comcast/Moto 6412 remote and Rotel 1056
        by deathstroke
        Does anyone have the remote code to operate a Rotel 1056 on the Comcast/Motorola 6412 DVR?
        17 March 2005, 16:14 Thursday
      • sikoniko
        SSP-800 Setup assistance
        by sikoniko
        It seems there are some people having issues with getting the SSP-800 setup. It seems to me that we should create a category so people can find information easily instead of letting it get burried with other conversations.
        Tip 1: Setup your first input to receive an audible signal...
        18 October 2008, 11:33 Saturday
      • Vicente
        Help, how to connect Musical Fidelity X-can and RSX-1056
        by Vicente
        I just bought a Musical Fidelity X-Can V3 and Senheisser HD650 headphones that seems to be a winner pair, but I have some problems to find the correct conections.
        Following the manual I plugged the MFX-Can (line in) to the Tape-Out outputs of the RDX-1056.
        As it says in...
        27 December 2004, 07:20 Monday
      • VladDracul
        RSX 1056 freezing and shutting down on its own
        by VladDracul
        I've owned a Rotel RSX 1056 since december of 2004. I've used it exclusively in a stereo setup connected to a Denon DVD-3910 as the sole source. It had been working fine until last week, when out of the blue, it began experiencing some strange issues. They are as follows:
        22 April 2005, 10:35 Friday
