Couple Problems with RSX-1055
  • italia
    • Sep 2003
    • 13
    1. When I switch channels while watching TV, about 20% of the time there will be no sound from the new channel. This is completely random and irrespective of channel. To get the sound back I can either turn the receiver off and on or go to another channel and come back. This is very frustrating. Why is this happening?
    2. I noticed tonight while watching, appropriately enough, The Tonight Show that Leno's monologue was not properly synched. I think the sound was delayed, but it was very noticeable. Watched a program just prior to that and didn't notice a sych problem.... so that leaves me pretty confused.
  • art vandeleigh
    • Oct 2003
    • 49
    i just had the #1 problem today. i have had my 1055 for about a week with maybe 5 hours on it. i was listeneing to my cd player and when i went to switch out the disk and put the new one in, there would be no sound comming form the 1055. it was if the 1055 was not even on. usually there woudl be a little background noise, but there was NONE.
    so i just turned off the 1055 and that solved the problem. so i decided to switch the cd again and it happens again. but this time i just stopped the cd play and tried to play again...and that solved the problem.
    so what the heck is going on??? this is the first time this has happened.
    • Scarp
      • Mar 2003
      • 632
      The lip synch problem can also occur due to the transmission. I've seen it with some sattelite stations too.
      If you have the audio connected through an analogue input its hardly possible for there to be a delay. Also with digital inputs I've never seen real lip sync problems with my RSP1066, the processing is lightning fast.
      About the no sound when switching. Do you have it connected analogue or digital? Maybe there is no signal lock? Do you have the latest firmware version on the 1055?
      • italia
        • Sep 2003
        • 13
        Yes I have the latest firmware. I am connected via digital coax to my satellite receiver. Signal lock? Yeah, I don't think there is.
        Art: I have not had the same problem that you have had with teh cd player (running analog to my RCD-1070).
        • art vandeleigh
          • Oct 2003
          • 49
          i am running optical from the cd player to my 1055...i will pay close attention for the next few days.
          • spizzi
            New Member, New Rotel RSX-1055 (giving my humble opinion)
            by spizzi
            What's the word big birds? I am joining this forum per the recommendation of a reviewer from audioreview.com that read my latest review. I have some qualms about my purchase as I used to be a faithful Marantz owner and it looks like this is the right place to rock.
            Not that you want to...
            20 August 2003, 13:44 Wednesday
          • Poul
            RSX 1055 Redirect Problem
            by Poul
            Hi All,
            I posted about this problem a couple of weeks ago but received no responses, so I'll try again.
            The problem in a nutshell is:
            When you set the 1055 to REDIRECT the front amps to centre back, something unexpected happens:
            (keep in mind that...
            28 March 2003, 02:04 Friday
          • Poul
            by Poul
            Hi All,
            My Centre rear speakers got cooked the other day!
            I'm not sure if I have a problem with my amp or I have set someting up incorrectly; here goes:
            In my set-up I power the centre, the surrounds and two centre rear speakers from the 1055 and I have a...
            18 March 2003, 04:17 Tuesday
          • gillen
            RSX-1055 reset problem
            by gillen
            My RSX-1055 sometimes reset to factory default preset, so I must reenter the parameters again.
            I sent to Rotel service and after a month they returned me with no problem verification.
            Anyone knows this problem?
            Thank you
            Gil
            08 June 2004, 12:21 Tuesday
          • Arnold van Oostrum
            1065 - big problem
            by Arnold van Oostrum
            I have a really big problem with my RSX-1065. It's not easy to explain. I'll give it a try.
            For some time now I have a problem with 'pink noise' in the surroundspeakers. It's not really pink noise, but I don't know how to describe it. It sounds like having a bad distorted reception on...
            21 September 2002, 05:37 Saturday
