I have a bizarre problem. When I go to the speaker setup menus on my 1098, it will not allow me to pick the test tone item. I can get to any other area of the the setup but not the test tones. Any one have any idea what this means?
Problem with 1098
by mkI calibrate my system (5.0 , all the same speaker except the center and no sub) here the result given with the internatl 1098 test tone :
FR:0
CENTER:-1
FL:0
SR:0
SL:5
What is very weird for me is the difference of 5 db between the 2...-
Channel: Club Rotel
by Aussie GeoffHi,
It was suggested to me by one of my sources that the DSP EPROM update in the latest RSP-1098 firmware release (plus the native EPROM code in the RSP-1068 and RSX-1067) fixed the issue that many of us RSP-1098 owners had with the Sub level in the Test Tone menu being 10 dB too low...-
Channel: Club Rotel
by zeppelinI have 1 question about the Test Tone on the centre channel.
When I use the SPL meter to calibrate my centre speaker using the internal pink noise from the 1066 at 75db, the centre is set at 0db.
But when I use the Test Tone from my DVD source pink noise like the "Video Essential"...-
Channel: Club Rotel
by ka724kaHi,
I just owned this receiver to replace with my old cheap one that I brought 5 year ago.
The setup was pretty smooth. I hooked up all 7 speakers which I used on the old receiver, when I tried to test them with test tone in the setting, I found out there is no test tone output...-
Channel: Club Rotel
by nashI've never really used the LFE output on my 1066 since I use Def Tech towers with built-in subs. With just the towers hooked up to L/R, the sound in movies is great and there's plenty of low frequency response. However, I thought I'd experiment and see how it performed differently if I used the optional...-
Channel: Club Rotel
- Loading...
- No more items.
