Problems with external remote input Rotel RSX-1056
  • EdwinRotelUser
    I have a Rotel RSX-1056 Surround Receiver. I have problems with the external remote input of the RSX-1056.
    The problem is that the RSX-1056 don't react on the sent IR-signal via the external remote input. Controlling the RSX-1056 with the remote via the internal IR-receiver in front of the RSX-1056 don't give any problems.
    I use a Xantech remote system. I have used several systems of Xantech en several IR-receivers. But with no good result. I used the same Xantech system on an other RSX-1056 and that works fine.
    The remote I use is the RR-1050, the standard remote of the RSX-1056.
    I don't think the problem is the Xantech system, but the RSX-1056 external remote input.
    Has anybody have/had this problem also ??
  • Kevin D
    • 4601
    Where is the IR receiver? If it's next to a plasma or in an area with a lot of sunlight, you'll have issues.
    Kevin D.
      • 16478
      I've used a similar system for years on all my Rotel gear and its always worked perfectly. If you say its not the IR repeater then I'd consider having the 1056 looked at by Rotel. You could try plugging the IR repeater into the second zone input and see if it picks up the signals properly there and as Kevin points out plasma TV's and sunlight can block the signals as well
        Widescreen Review Magazine article on Sony HS-10
        For those who were asking, here's a "hard" copy of the review. This PJ is one that I've been looking at for a while, and finding good stuff.
        Sony VPL-HS10 Video Projector
        Champagne Video On A Lemonade Budget
        By Greg Rogers
        29 January 2003, 05:14 Wednesday
      • Burke Strickland
        Anybody using the multichannel input instead of "direct" for analog sources?
        by Burke Strickland
        I just got an email from someone who shall remain anonymous unless he volunteers to come forward and identify himself. :>) Actually he asked a good question that I thought might be of general interest, so I’m posting the answer here in addition to answering the email.
        He wants to...
        17 July 2004, 02:38 Saturday
      • Howard Schneck
        Using Remote IR Reciever
        by Howard Schneck
        I have a question about hooking up a remote IR receiver to my RX-1052 receiver. I just want to control my RCD-1072 CD player from another room where my good speakers are located.
        There is an EXT REMOTE jack on the back of the 1052. Shouldn't I just be able to hook an external IR Xantech...
        16 September 2005, 21:02 Friday
      • cameronl
        Xantech with C2
        by cameronl
        hi all, I have some questions regarding xantech that I am hoping someone can help with
        1. can I plug a xantech ir receiver directly into the main ir input on my c2?
        2. can I plug a 3.5mm jack (mono?) between the zone 2 ir input on my c2 and a xantech CB20. I want to...
        12 August 2008, 06:05 Tuesday
      • TTA89
        RSX1056 Sound Issue
        by TTA89
        Well I don't know if this is a bug or something I don't have setup right but here is the deal.
        I use my DVD player as my CD Player as most of you guys do as well. I have 2 different inputs setup as I default input "CD" to PCM 2 Channel and Default input "DVD" to DPL2....
        10 November 2004, 10:31 Wednesday
