Hi, I'm new to the forum and would like advice on how to get two new fuses for my Rotel RB971 power amp. The two fuses that cover the left channel have both blown and next to them is a sticker which reads: 250v T3.15AX2. What type of fuses are these in laymans terms, and how do I get hold of them? Cheers, John.
Blown fuses....HELP!!!!!!
by tomasitoHello,
Has anyone changed the fuse in a RB-1095.
I don't get audio coming out of the rear channe, I think one of the fuses is blown. I opened the 1095 and the fuses are buried way in the PCB.
I experienced this with the 1080, It was a blown fuse. The fuses in the RB-1080...-
Channel: Club Rotel
by dinnuHi Guys,
I am trying to see if I can just replace the fuses on my RB1080 to fix my dead (right) ch prob. I noticed two 6.3 A fuses and I couldn't figure out if they were blown or not. So, I just switched them to see if it would switch my dead ch (i.e., make my left dead and right live)....-
Channel: Club Rotel
by ZissouHave what until today was a perfectly functioning Cinenova 5.
Well I have had an issue, not a small one, and am very upset with Earthquake's response. We had the system on playing a movie as background noise when I heard a loud POP and a strange noise I'd never heard before. I glanced back at...-
Channel: Audio Hideout
by rantzmarHelp.
I think I have a blown fuse in my RC1090 preamp. I took of the cover and saw that the fuse had a clear cover over it with a warning do not remove unless a trained tech. I suppose the warning is because of the power supply, but by just looking at the fuse it looks broken. Its a very...-
Channel: Club Rotel
by rotel&energyHey guys,
This is my first post in a long time, and unfortunately I'm going to open up an old issue - blown left channels on RB-1080s. I've had my 1080 for over 2 years, using the 12 volt trigger, without any problems. Just the other night, I came into the family room and noticed I...-
Channel: Club Rotel
- Loading...
- No more items.
