SACD and DVD A without subwoofer
  • antonyantony
    • Jul 2003
    I would like to buy a 1066, 1095 B&W large speakers and a Denon 2900.
    I do not want to use a Subwoofer.
    Can I set 1066' parameters to send the LFE .1 channel to the others speakers?
    • 16507
    No but there's not many disc's with content on the .1 track anyway so I wouldn't be concerned.
    • Matt Sprouls
      • Apr 2003
      • 83
      You should be able to set the Bass Management on the Denon 2900 to redirect the .1 LFE to the large speakers.
      Matt
      • antonyantony
        • Jul 2003
        I ve seen that the Denon 2900 LFE chanel is -10 db bellow the reference level? It is not true ?
        I ve read that you have to increase the input level by 10db.
        • Scarp
          • Mar 2003
          • 632
          Sure, set "subwoofer" to off in the speaker settings of the 1066. That should theoretically work. However doing bassmanagement in the player is even better.
