RSX-1055 power
  • Nate
    • Feb 2003
    • 10
    RSX-1055 power
    I currently own the RSX-1055 and I use it to push a couple of B&W 9NTs. I want to start using my system for more HT. However, I am on a budget right now, and I'm not sure how much I can really spend.
    My main question is, if I was using the 1055 to push five speakers, would it decrease the life of the speakers and/or the receiver? I am thinking about buying the RMB-1075 for more power, so I know that would help out. But then more questions come into play! I have heard some people talking about biamping and how it wasn't good for B&Ws. Is that true?? If it is, I could use the 1075 to run the fronts and center, and use the 1055 for the surrounds (and eventually the backs for 7.1). I have been reading a lot of these threads, and I have heard a lot of opinions about using too much or too little from the amps/receivers.
    Please help! I figured I could get more help here than someone that is trying to sell me more equpment. Thanks.
  • Glenn
    • Jun 2003
    • 109
    Nate
    What is your opinion on the power level of the rsx-1055 combined with the 9NT's, in a two channel set-up? Does this particluar combination match and work well for you?
      • 16478
      No it won't decrease the life of either product. The only way you'd damage your speakers is if you turned it up to a loud enough level that the receivers amps clip...fortunatly you're likely to have run out of the room by that point so i wouldn't worry about it
      That's a nice amplifier
      I've love to hear why they think it would be bad :roll:
      Well that's not a bad idea...i'd bi amp the mains and power the center with the 5 channel amp and let the 1055 power the sides and rears if you have them.
      That said before you buy the 1075 you might want to spend some time with just the 1055 powering your speakers....you might find its all you need. The 1075 will make the sound cleaner during stressfull passages but if you are only interested in movies you might find the 1055's internal amps provide you with all you need...esp if they're all set to small and you have a powered subwoofer.
      • Nate
        • Feb 2003
        • 10
        Thanks for the help, Andrew. I will probably stick with the 1055 for a while and maybe go for the 1075 later when i get some more money. :LOL:
        I am about to finally upgrade my 1055 with the latest software. Have there been any problems with the upgrade?? I have seen some threads about receivers that stop working after the upgrade. Does Rotel fix these receivers or give people a new one when they download the software and it stops working? I have already had to return my first 1055 to the dealer because of another issue that i never learned about. Rotel gave me a new one pretty quick...but, i don't want to go through that again. I have looked at the instructions, and they look pretty straight forward to me. I was just curious about the return policy on upgrades....
        Thanks again for the help. I have learned so much from the forum....
        • Energeezer
          • Sep 2002
          • 147
          That is a good idea. Not sure why I hadn't thought of that myself.
          The Future of HT lies in FP SPREAD THE WORD
          • Danbry39
            • Sep 2002
            • 1584
            Don't quote me on this, but I think, in a worse case scenario where you couldn't get the receiver to work whatsoever after attempting to upgrade the firmware, you could send it back to Rotel and they would upgrade it for you. Most who have had a problem where the upgrade went wrong, tried it again and were able to correct the problem themselves. Usually, it was something like not flicking the switches back or attempting to upload with the receiver on "sleep" as opposed to being "turned off".
            Andrew, do you know? I just think Rotel wouldn't have a problem at all doing it for him, if all failed.
            Keith
            Keith
              • 16478
              The only way to really screw up the upgrade process would be if you tried to flash it with the wrong firmware...ie. upgrading a version 1 model with a 2.XX firmware. I think that locks up the chip and would require it going back to Rotel...other then that it should work fine. As other's have mentioned in all other cases here when something didn't work correctly we were able to trace it back to a bad cable or something else that was easy to fix. If it doens't work the first time just try it again...it sometimes takes a couple of trys before it takes it...which although can be a little scary its nothing to worry about.
              • Nate
                • Feb 2003
                • 10
                Sounds good. I should be getting my cable tomorrow so i will let 'er rip! :a>'>
                Thanks for all of the help.
                • johnmark
                  • Jun 2003
                  • 3
                  I have been using the RSX 1055 to power the CDM9's for 5 months now and I do not think more power is needed. I had an RB991 in the system for a while and I could not tell any major difference between the 991 and the 1055 amp. I got alot more bang for the buck out of good cables. I do not listen too extremely loud music, but I have yet to hear clipping at the loudest volume my ears can take. On the other hand that extra power is always attractive.
                  • Glenn
                    • Jun 2003
                    • 109
                    Johnmark
                    Thanks for the 1055 / 9NT reply. It's difficult to know the combination of different set-ups, especially when sometimes it's not possible to get to a dealer, or to have them rearrange their showroom. Nice to have the input of others who have had the chance to evaluate.
                    When you listen 5 channel, the 1055 still is sufficient to drive the 9NT's? What are the remaining speakers in your system?
                    • Nate
                      • Feb 2003
                      • 10
                      Glenn
                      I own the 9NTs and the CNT center channel. I also own a couple of older bookshelf speakers for the surrounds. I think that it sounds great in HT. I haven't had any problems with the amps in the 1055. I not only wanted the extra amp for the 7.1 setup, but for better sound overall.
                      Thanks for all of the input. I have been spending a lot of time at my dealer...it is really hard to get away from there! They mainly use the Rotel/B&W combination there, and they suggested to set the crossover at 60 for a sub with these speakers. Not one complaint so far! And after upgrading the 1055, i think i will be set for a while.
                      • Glenn
                        • Jun 2003
                        • 109
                        Nate
                        I'm very close to FINALLY finalizing my HT purchase decisions. Thanks for the info.
                        • johnmark
                          • Jun 2003
                          • 3
                          Glenn,
                          I use a couple of soon to be replaced Klipsh's for the rears. They are very efficient speakers.
                          I have played movies, SACD and DVDA in 5 channel and still have plenty of power. The "Dark Side of the Moon" SACD has lots of dynamics and it plays loud and smooth with just the 1055.
                          I'd suggest buying the 1055, let it break in, then see if the dealer will let you demo a 1080 to see if you can tell the difference. If you have not biwired the CDM9's do that first. That was the best thing I did to upgrade the system.
                          John
                          • Glenn
                            • Jun 2003
                            • 109
                            Johnmark
                            Few more weeks until my 1055 purchase and I will be trying the very suggestions that you've offered, I can't wait! And thanks!
                            • BleakShore
                              Stick to RSX1065 or go to 1055/1075 separates?
                              by BleakShore
                              I guess I'd like to hear/learn advices/experiences from those who have gone this route.
                              That is, stick with the RSX1066, or exchange it for the RSX1055/RMB1075 combo? I bought it from Myer-Emco so I can do the exchange with no penalty.
                              The reason I'm contemplating this...
                              17 October 2003, 13:27 Friday
                            • dgirvan
                              What to do with my 1055....
                              by dgirvan
                              Hi guys this is my first post here and by the way this is a fantastic forum.. Ill cut to the chase.
                              Ive just Purchased a new RSX 1055 and the MK 750THX pack and have few questions.
                              1. Does anyone know if the Aussie 1055's have HD compatability?
                              2. I was really keen on using a RMB...
                              12 February 2003, 03:44 Wednesday
                            • Bonster
                              1055 + 1075 and zone 2... (one more time!)
                              by Bonster
                              First and foremost, thanks to all for helping me in my decisions. I'll be posting pics soon of my very modest Rotel / B&W setup
                              RSX-1055 (firmware upgraded to 2.26)
                              RMB-1075
                              B&W CM4's (fronts)
                              B&W LCR60 S3 (center)
                              B&W DM 600 S3 (surrounds)...
                              24 October 2004, 20:54 Sunday
                            • gostan
                              1055 Receiver+Power Amp w/SACD-DVD-A
                              by gostan
                              I have noticed a number of suggestions for those of us on a budget (all of us?) that a 1055 and a power amp to run the fronts is a similar sounding and better alternative to a 1065 receiver, and not that dissimilar to a 1066-1075 combination. My understanding is that with multichannel audio, equal power...
                              23 June 2003, 05:34 Monday
                            • Armond
                              RSX-1055 Wont power up
                              by Armond
                              Hey guys,
                              My amp is on stand by mode...the blue light is on but when I press the power button on the remote, nothing happens. Just a click and a short hum and none of the lights on the front window lights up....I'm bummed....any simple fixes?
                              03 January 2006, 22:40 Tuesday
