Source for replacement multi-channel cable?
  • jakermc
    • Nov 2001
    • 24
    Well I am finally taking the plunge into SACD and DVD-A with the help of Outlaw's ICBM. What I would like to do, instead of using the supplied cable, is buy a higher quality cable with a DB-25 connection on one end and MALE RCA plugs on the other. This would allow be to plug the cable directly into the ICBM instead of using the supplied cable as an adapter (its RCA connectors are female).
    Does anyone know where I can find such a cable?
  • Burke Strickland
    • Sep 2001
    • 3159
    A few options to consider:
    1) Monster makes a cable like you are looking for, shown at onecall's site priced at $109.95 (including shipping) for a 2 meter cable (6.6 feet) http://www.onecall.com/PID_11171.htm
    2) CableLand advertises a line of this type of product starting at $99 for three feet long: http://www.cableland.com/audio/mcadb10.html
    3) You might also try a custom cable assembler such as ElectroTex http://www.electrotex.com/cableform.htm
    Although I don't know specifically if they do the DB-25-to-6 x RCA converter, they build just about any kind of cable "out there" to customer specifications, so it might be worth giving them a call. (800) 460-1801 (I would call them myself right now to find out, but they are closed for the day.) For a one-off special fabrication, they may not be any cheaper than the other options, especially if they've never done this particular design before. But what the heck -- it's a free call. :>)
    Good luck!
    Burke
    • jakermc
      • Nov 2001
      • 24
      Thanks for the links. You are like the old Shell answer man. Is there anything you don't know?
      • dschamis
        • Sep 2001
        • 28
        I got one from www.bettercables.com.
        It cost me $99 plus S&H and have been very happy with it.
        I think its hard to say whether it is better or worse than the Monster cable - probably depends on who you ask!
        David
        • Greg Staten
          • Sep 2001
          • 17
          Call me crazy, but why not use male-male adapters and the existing cable?
          Let's be blunt. I'm a video editor (and not with toy gear - I cut on an Avid Symphony) and to be honest, I'd use male-male adaptors. We're talking about $10-20 max for the adaptors (you can get them from a variety of vendors - including Radio Shack). They are in all likelyhood straight metal connections.
          I seriously doubt there'd be any signal loss. Can anyone honestly say me that a hundred dollar cable sounds better than the existing cable and $10-20 worth of straight wire adapters???
          -greg
          • Rotel4Life
            DB25 cable caused all my issues in RSP-985
            by Rotel4Life
            Got a used 985 from an auction site. Looks perfect but had a hum on all inputs, all sources, on mute etc. If it was on, there was a hum. Also there was an audio 'hiccup'- like a 1/2 sec pause in sound every few minutes. My setup worked perfectly with an RTC965, nothing changed but swapping the 965...
            19 December 2012, 02:11 Wednesday
          • Jerm357
            Custom RCA to 1/4 mono subwoofer cable ?
            by Jerm357
            I want to make a subwoofer cable with a RCA connector and a 1/4 mono plug. I am planning to use a old MonsterBass™ 300 Subwoofer cable and use the one of the RCA on it and cut an end off and solider a 1/4 mono plug on the other end. Now the question is what a good 1/4 mono plug that will fit on this...
            31 May 2006, 14:05 Wednesday
          • costafinkel
            WHAT CABLES SHOULD I USE TO HOOK UP MY ONKYO HT-S3200 TO 40" LCD AND BLU RAY PLAYER ?
            by costafinkel
            Here's the thing, my stepfather has a 40" LCD and Blu ray player, both samsung.
            I just received (TODAY) this Onkyo HT-S3200 and I'll hook it there. But in some months I'll take it to my home where I have a 32" LCD and a hi-def dvd player with hdmi jack.
            But when...
            17 December 2009, 21:22 Thursday
          • Chris3G
            best way to connect ICBM to 1066 w/ new firmware?
            by Chris3G
            As per Dre J's bass management reports and solutions, the best way to connect the 1066 and an ICBM (not including 5.1 inputs) is to set the sub to "off" in the 1066 menu setup, sending LFE bass to the front channels, and then letting the ICBM sort it out. The downside to this setup is the...
            26 February 2003, 18:46 Wednesday
          • frasse74
            xlr to rca
            by frasse74
            Hi all
            i have seen that this subject has been talked about before
            but i have some other questions..
            If you use a balanced cable from your preamp and have the adapter
            on your xlr-cable or is it better to have the adapter on your preamp
            and use a rca cable...
            09 February 2008, 10:51 Saturday
