Integra DTR 5.3 w/ KEF sub question
  • mjt444
    • Oct 2009
    • 3
    First post - apologies in advance if this is in the wrong thread.
    Current setup: Integra DTR 5.3/DPC 7.4 with KEF PSW 1150 and the KEF HTS 2001.3 satellites (eggs) as wall mounted surrounds. My fronts are B&W DM303 and the matching LCR3 for center. I just purchased the DM 303s from craigslist so I could timbre match the front three. I'm now trying to tune the overall setup and integrate the sub.
    My questions: I have the crossover set to 80 on the DTR - any higher and the sub dominates the sound. On the sub itself, I have the phase at zero and the crossover turned all of the way up. The KEF sub has a slope switch for 12db or 24db. Does this switch make a difference or does the Integra simply cut over the sound at 80? What should I hear differently between the 12 and 24 settings? Overall, the sub is quick to sound muddy or simply too loud. I've played w/ the volume on the sub and the DTR levels, but am never quite happy with the sound for long. The sub is sitting on the bottom shelf of a bookshelf, but it is front firing. Opinions on the KEF sub in this setup?
    Thanks for any guidance or opinions. Finally, when the sub is tuned just right the system sounds great. Should I need to revisit the sub settings every time I watch a movie?
  • Ovation
    • 2204
    Your sub placement is less than ideal and is likely contributing to "muddy" bass. You should keep the crossover on the sub turned all the way up and let the receiver handle it. The slope switch is not important if the receiver is doing the bass management, so if it has a neutral or "off" setting, I would use that. If not, then set it to the steepest slope (24 dB) as that will minimize upper frequency "bleed-through".
    If I were you, regardless of settings, I would try to find another place for the sub (out of the bookshelf).
    • mjt444
      • Oct 2009
      • 3
      Thanks for the reply. I'll try moving the sub.
      • len73
        What sub for Kef iQs ?
        by len73
        Hello everyone !
        Will be going to my dealer this we to listen up to different systems, and am still not fixed which sub to take ...
        System will be installed in a small room (arround 12 square meters) and should (!) consist of : Rotel 1068+1075, Kefs iQ9, iQ6c and iQ7 +...
        01 June 2006, 06:34 Thursday
      • chuck21401
        Integra DTR 40.1 - Zone 2
        by chuck21401
        I recently purchased an Integra DTR 40.1 receiver to replace my older Onkyo receiver. Before the Integra I had a TX-DS 939 and before that a TX-DS 747. The Integra is a great leap forward and sounds great.
        I am using the Integra in a home theater set up and have two outdoor speakers...
        05 January 2010, 12:51 Tuesday
      • Denun
        need advice on dtr-10.5
        by Denun
        i hope u can help me b4 spend so much money on this receiver
        there r difference between onkyo tx-nr1000 and integra dtr-10.5? i mean there are features difference or are really the same?
        i can buy onkyo tx-nr1000 @ around 3200$ new from the shop
        and i can buy...
        07 April 2006, 23:13 Friday
      • dizedean
        Integra DTR 7.6 vs Harmon Kardon AVR 435
        by dizedean
        I am in the process of buying a new home theater system. I have decided on a Pioneer Elite Pro 930 HD as my TV. I am going to use B&W 600 series S3 speakers. I need to decide on a reciever. I have been touted on 2 different products.
        The B&W salesperson is pushing an Integra DTR...
        14 May 2006, 21:40 Sunday
      • dizedean
        Harmon Kardon AVR 435 vs. Integra DTR 7.6
        by dizedean
        The B&W salesperson is pushing an Integra DTR 7.6 versus...
        14 May 2006, 21:44 Sunday
