ASW 4000 Subwoofer problem
  • digitalman
    • 29
    I just acquired an ASW 4000 subwoofer. It powers on, I tried all inputs and i just get a low level output with a bunch of distortion. I tried every combination of all the settings. Nothing effects it.
    Any thoughts?
  • madmac
    • Aug 2010
    • 3122
    Wow!! Nice subwoofer.....it's a monster!
    What output to it are you using from your amp/receiver ??. It looks like this unit has a lot of input options as well. Did you get the manual with it?
    Dan Madden :T
    • digitalman
      • 29
      Yes it has a plethora of input combinations, i tried them all and have the same results from every one. I downloaded the manual. It is very large and weighs a ton. I can't wait to get it going for movies. I read some people complain its not very "musical" but I will only using it for movies so it will rock my theater. I guess i will need to take it to a local repair shop and hope it is not an expensive fix.
      • pdmonty
        • Nov 2014
        • 21
        Hmmmm
        I was doing some research on this same problem and from what I can tell it sounds like the distortion is coming from a damaged or blown amp. From what I've read that's an amazing monster sub so definitely worth getting it fixed
        Good luck!
        Paul...
        Current Modest Equipment:
        B&W 703's (MAINS)
        B&W HTM2 (CENTER)
        B&W 686's (REAR SURROUNDS)
        DS7 (SIDE SURROUNDS)
        B&W ASW750 (SUB)
        B&W AS6 (SUB)
        MARANTZ AV7701
        MARANTZ MM9000 (2) (5 CH AMPS)
        MARANTZ MM7025
        MARANTZ MA6100 (2) (MONO AMPS)
        MARANTZ UD5007 (SACD/BD/CD)
        MARANTZ CD67SE (CD)
        PANAMAX M4300-PM (POWER CONDITIONER)
