B&W ASW-CM Subwoofer Bass Unit Rattle
  • bnieman
    • 202
    Hello all,
    My ASW-CM has developed a rattle in the bass unit. I took apart the sub to isolate the problem and unfortunately it's not a screw tighten fix. The bass unit rattles even when held outside of the cabinet.
    Here is what the rattle sounds like: http://bryan.frommfamily.com/bw-sub-rattle.m4a
    The rattle only occurs once you have sufficient bass at a certain threshold. The threshold is pretty low, when sending a line level signal to the sub it will start to rattle around 1/4 volume.
    Does anyone have any ideas? Or should I bring it in to my dealer for repair? The replacement cost for the bass unit on B&W's service site is $423.54 but they have zero in stock.
    Service Manual: http://bwgroup-support.com/downloads...SW%20CM-TM.pdf
    Cheers,
    Bryan
    Guide: Ripping DVD-Audio Discs (DVD-A) to FLAC in Windows
  • windshear
    • 243
    Check your pigtails. These are the flexible wire leads going from the terminals to the voicecoil. Firstly they should have enough flex in them, secondly check for no dry joints on the contacts and thirdly, check if the pigtail is glued to the spider edge and may have worked loose, causing a rattle. I have encountered all 3 these problems recently on a pair of 802D's.
    • bnieman
      • 202
      Thank you for your reply windshear.
      Are the pigtail leads the leads in the picture going from the cabinet to the bass unit? If so I made sure those were secure and when I played music while holding the bass unit in my hands I could tell the rattle was not coming from the leads.
      I did not see any other leads and I do not see any in the service manual either (page 2 http://bwgroup-support.com/downloads...W%20CM-TM.pdf).
      Best regards,
      Bryan
      • windshear
        • 243
        No the pigtails are the leads that go from the connector on the actual driver into the inside over the spider and then the voicecoil.
        The other possibility iis that the spider has collapsed. If that is the case then changing the orientation of the driver would either reduce or accentuate the effect of the voice coil rubbing.
        • bnieman
          • 202
          I did try holding the driver in different orientations and it did not affect the rattle (it neither reduced or accentuated it).
          Does checking the pigtails require dissembling the bass unit itself? If so that is a bit out of my comfort zone as it would appear it takes a bit more than the hex screwdriver I used to open up the cabinet and pull out the bass unit.
          Again thanks for the information, I think I will take the sub into my dealer tomorrow (they are closed Mondays).
          Cheers,
          Bryan
            Sub death rattle?
            by Jim Holtz
            My beloved Stryke AV-15 has started to develop a rattle. I've been looking for a match to add another AV-15 unsuccessfully for some time. This may change my direction. I do need to do some more investigation but it now points to the driver going bad.
            I'm not an over the top sub guy. I found...
            06 February 2010, 13:47 Saturday
          • Club1820
            Sub Setttings - Lack of Bass
            by Club1820
            Hello. I have a couple of questions regarding the settings for the sub on the 1068 pre/pro.
            I currently have my M&K VX-860 250 watt sub volume level set at Reference and also set to bypass its crossover settings in favor of the pre/pro. On the 1068 I have the crossover set...
            25 January 2007, 16:09 Thursday
          • boffo
            bass issues with RSP-1572 and Oppo UDP-205
            by boffo
            Hi, folks! I have a quick question:
            I use the Oppo's analogue outputs to feed the Multi inputs of the preamp/processor and it works great for most things. However, I find that I sometimes get far too much bass from movies in surround than I do from stereo audio. I've tweaked the M&K subwoofer,...
            20 June 2019, 11:46 Thursday
          • HeatMiser
            Bass management questions: DIY subs, pro amps, HT, music
            by HeatMiser
            Thanks to the wealth of information on this forum, I have been introduced to the benefits of using pro sound reinforcement amps (as opposed to plate amps) to drive DIY subwoofers. This solution would seem to demand a certain level of flexibility in the receiver/processor's bass management system that...
            16 May 2006, 13:38 Tuesday
          • Brandon B
            Passive Aria 5a+actively XO'ed bass unit
            by Brandon B
            Since I am stalled on dual HE15 by delays on the parts and my new dilemna of whether to go ported or use the PR's, I guess I'll look for some feedback on the rest of the system I am building.
            I am building a 7 speaker surround setup which will hopefully perform musically as well. It is...
            23 August 2001, 19:59 Thursday
