Need some help from the experts.
My system is 202-700-2200-802D
Due to my living place I’m quite restricted in the way I can position my system.
So speakers are 3.60m from each other, listening position is about the same distance.
There is chimney, 80 cm deep, between the speakers (yeah I know what the B&W brochure says about chimney…), situated from the centre of the line joining the speakers and extending towards the right speaker. Only 10 cm of the depth of the speakers are hidden by the chimney, the rest of the speakers are free of its influence ( or anyway I believe so…).
Moreover, the distance from the back of speakers to wall is not the same on both sides, it’s about 70 cm for the left speaker and 50 for the right one. Also the material for this wall is not the same..
My problem is this, most of the time when I listen to music I have this strong impression that the soundstage from center to right is a bit dead, or too prominent on the left side.
Understand me correctly when an instrument is mixed to appear in the right hand speaker I hear it loud and clear; it is everything that is between the centre and the right which is a bit shy.
My wife describes the same phenomena as instruments look closer on the left.
Made a measurement with a sound meter and in order to have the same level I have to put the balance around 1.0 on the right.
Initially I was thinking that some cds were badly mixed, not well balanced; but it makes no sense as it is always the same left side more present, never the right one.
When I put the balance around 2,5 on the right side, sound looks more balanced.
I remember reading something on this forum about someone who had a similar issue (soundstage stronger on the left) but I can’t retrieve it…. Also I’m not sure I have an issue or not, I mean for the electronic part.
So what do you think?
Acoustic problem, speaker problem, cable problem or electronic problem?
Any advise will be really welcomed, as lately I’m more zapping the songs and playing with the balance than enjoying music ….
Birdy
Birdy
