703s is Rotel RB-1090 (380watts x 2) too much power?
  • orangebull
    • 16
    I have a pair of 703s for my main speakers. I am looking to buy a new Rotel amp for my main speakers. I currently have 1098 processor and RB-1075 130w x 5 amp).
    I am trying to decide between the RB-1080 and RB-1090. From reading the specs of the 703s it indicated power handling of 50 - 200 watts. The RB-1090 is rated at 380 watts per channel.
    Does this mean that since the amp is capable of 380 watts that it is too powerful for the 703s that seem to have an upper end of 200 watts?
    I found a 6 month old RB-1090 for $1,200 slightly used, but in mint condition. A new RB-1080 is about $1,000.
    thanks,
  • azsyno
    • 50
    I'll be interested to see what the experts say on this - I suspect the answer is that the 1090 is capable of 380 but it's not a continuous wattage and is therefore, suitable and perhaps, with all that power, a good fit.
    I have 703's and a 1080. They really work well with the 1080 and I'm thinking of getting a new AV Receiver (maybe Rotel) to drive the center, sub, and rears.
    Regardless, great speaker choice and hope you are happy in the end.
    • Ryx
      • 76
      I would take the 1090 without thinking twice. It is true that the 1090 is a little overkill for a set of 703s but more power will not hurt the speakers as long as you don't turn the volume up to rediculess levels.
      The 1080 is a good amp and would drive your 703s just fine but at the price you can get the 1090 for it is just a better deal, and it has some benifits over the 1080.
      First if you decide to upgrade to a set of speakers with a higher power rating, you won't likely have a need to upgrade your amp right away.
      Second the Rb-1090 is rated at <0.01%THD at half rated power, so you would be able to take full advantage of that fact.
      and my final point is that the signal to noise ratio on the 1090 is margenaly better at 125db compaired to the 1080 at 116db.
      so overall I would say go for the 1090!!
      I am sure a few people will agree with me so wait till you get a few more replys if you are still unsure.
      • RobP
        • 4747
        The 1090 in my opionion would be a great amp for those speakers, in adition to the other advice about the benefits given, the extra power will also offer much better control resulting in less fatigue on your speakers and your ears, having power reserves is not always about decibles.
        Robert P. 8)
        AKA "Soundgravy"
        • orangebull
          • 16
          thanks
          I appreciate the advice.
          The 1090 it will be!
          • Twincam
            Rotel RC 1090 / RB 1080
            by Twincam
            I will soon move to slightly bigger house, and then use my Nautilus 804 for a pure 2 channel setup. My RSP 1098/RMB 1075 combo will be used in a separate room for a HT setup (connected to 805/HTM2/SCM1/ASW700).
            I am thinking of the Rotel RC-1090 / RB-1080 combo for...
            13 October 2004, 00:57 Wednesday
          • mfishmike
            RB 1090
            by mfishmike
            I'm looking to purchase the RB 1090 380 X 2 to finish off my system. I was sold a 1065 demo which needed upgrades. Is the 1090 upgradable, or if I find one used, does it also have upgrade issues? I'm hoping by driving the two mains with the 1090, the 1065 will be able to drive the rest of the system...
            18 March 2004, 20:19 Thursday
          • GenesisFreak
            RB-1080 vs. RB-1090
            by GenesisFreak
            Hi Everyone;
            I currently own a Rotel system using the 200W RB-1080 amplifier. I am thinking about trading up to the RB-1090. There is nothing wrong with my system (in fact, it sounds very very good), I am just curious to see the effect of basically doubling the amount of power for the...
            18 May 2004, 12:26 Tuesday
          • orangebull
            RB-1090 too powerful for B&W 703s?
            by orangebull
            I am trying to decide between the RB-1080 and RB-1090. From reading the specs of the 703s it indicated power handling of 50...
            25 November 2005, 09:25 Friday
          • specialized
            RC-1090 vs RC-1580
            by specialized
            Hi there.. Does anyone have a chance to compare those two preamps? Last week i tested a lot of electronics to complement with my B&W C1 setup. At the end the best sound give Rote RC-1090 / RB-1080 combo. Since i got this RC-1090 from friend just for test, and if im buying i can order RC-1580 (which...
            09 November 2010, 17:38 Tuesday
