I have an older Elite Receiver, the VSX-99, and I can't seem to figure out how to get the zone 2 outs to work on it. Unfortunately, I can’t find the manual and was wondering if anyone had any experience with this receiver or possibly any similar Elite receivers that may help.
Basically, the vsx-99 has a zone 2 L/R and video pre-out on the back. I ran a L/R composite cable from it to a stereo amp, which is hooked up to a Niles switch box. Everything seems to be in order, but I can not get a signal from the Pioneer. The vsx-99 has a button on the front face labeled 'multi-room & source', however pushing it seems to do nothing and I can't seem to find anything else that even sounds like it would select the source and/or activate the pre-out.
I have hooked a CD player directly into the amp and everything works fine, so the problem must be getting a source from the receiver. Hopefully, that made sense and someone can help. Thanks.
