Denon 5900 vs 3910
  • Chuck
    • Apr 2004
    • 30
    Denon 5900 vs 3910
    So this is what my local salesman said "the 3910 IS the 5900, plus better audio codecs and HDMI, only in the 2900 chasis."
    Does this pretty much some it up? So I'm in between ordering the much-preferred silver 3910 and the refurbished 5900. Should this even be a toss up?
    Thanks!
    Chuck,
    Sorry to muddy the water further, but does build-quality enter into the equation for you? If it's not important I'd go with the 3910, but if it is, then compare this between the two units. Look at the isolation set-up, the quality of individual components, the chassis itself. Then, decide if the differences in construction are basically worth giving up HDMI.
    For me, I'd take better quality design/construction/isolation over HDMI.
    As always, this is just my 2 cents. Good luck.
    • Shane Martin
      • 2852
      I personally wouldn't touch a refurb with a ten foot pole myself. The 5910 will be better than the 3910. If you want the 5900 series unit, then you'll need to pony up the extra $800. I can only imagine what they will do to the 5910 to make it much superior than the 5900..
      • nyny
        • 128
        Hi guys, here is a link to the comparison review between 3910, A11 (5900), and Pioneer 969 (59AVi) by AVBuzz.com (it's in Chinese): http://www.avbuzz.com/eq/3910/3910a.htm
        According to the reviewers, the 3910 has the best PQ among the three players. However, the reviewers were unable to test audio performance since they had to return the test unit to Denon.
        Now I am even more interested in the 3910....can't wait!
        Tony
        • Sonnie Parker
          • Jan 2002
          • 2876
          Personally if I can save the money I would prefer a refurb with a 2 or 3 year extended warranty. I have a refurb 2900 and it has performed flawlessly. I haven't heard of anyone having problems with refurbs from Denon as they are supposedly tested to spec before they are sent out for resale. There are several of us here on this forum who own or have owned refurbs and been very happy. Have you had a bad experience with a Denon refurb?
          Where have you heard about a 5910?... it's my understanding the 3910 is the replacement the 5900.
          • Shane Martin
            • 2852
            No but I do NOT trust them.
            Due out Decemberish I heard. This is the replacement for the 5900. Their 3910 is a replacement for the 2900. I'm trying to decide between a 2910 and the 3910 right now.
            • Adz
              • Jan 2004
              • 549
              The 5910 does exist and there is a wealth of information (and speculation) around it on the AVS Forum. What is clear is that the 5910, not the 3910 is the replacement for the 5900 but it will not be out until early 2005. Denon pulled it for now to accomodate "next generation technologies" and speculation is running rampant about the new features including the next generation Faroujda DCDI and Silicon Image technology and maybe even BlueRay /HD DVD support. Expected retail price is $2,500, so start saving now.
              I have three college savings accounts. One for Jordan, one for Sarah and one for Denon! :W
              Adz
              • jimmyp58
                • 1449
                Uh-oh ADZ, what was I saying to you a week or so ago that I'd put off upgrading my DVD player for a couple of years?! Yikes....
                :E
                jpiscitello@ameritech.net
                • Chuck
                  • Apr 2004
                  • 30
                  Thanks adz. I'm starting to feel a little stupid for buying a Rotel earlier this year. Don't get me wrong, it sounds pretty good, but it doesn't have hdmi or ilink or whatever for dvd-audio which is now a twist in the panties. So maybe I should wait for the blu ray / hd dvds and rid myself of future regret.
                  • Chuck
                    • Apr 2004
                    • 30
                    One more question, any suggestions for stand alone Dvd-audio / sacd players? I wouldn't mind putting some money into a seperate player. My current dvd player doesn't support either, but does have dvi out (samsung 931).
                    • Azeke
                      • Mar 2003
                      • 2123
                      Chuck,
                      I recently purchased the Pioneer Elite 59AVI to replace a three year old DVD player. However, I am still breaking it in, but it has both DVD-A and SACD capabilities. I am uncertain of how it will compare with the new Denon line, but I am happy with my purchase thusfar.
                      Azeke
                      • BlazeMaster
                        • 644
                        yup, I bought my 2200 just about a year ago, AND from a unauthorized dealer. It's performed flawlessly this far. I wouldn't pay another $1000+ for a DVD player until HD DVD/Blue Ray comes out in the market. It'll also give most current DVD players a price drop.
                        • LEVESQUE
                          • 344
                          Kris Deering from Secrets just said the 5900 has a better frequency response then the 3910 also. Full Secrets review shoud come out soon.
                          The 3910 is replacing the 2900, and the 5910 will replace the 5900 around january. The 3910 is a 5900 with slightly different DACs, only 1 power supply (the 5900 has 2 independant powert supplies) and a lesser build quality. So far, reviewers are saying the PQ is a bit superior with the 3910 (with an inferior frequency response?), but audio wise the 5900 is still superior.
                          Also, the 3910 has a S/N ratio of 118dB and THD of 0.0009% compared to the 5900's S/N ratio of 120dB and THD of 0.0008% This may be partially due to the use of different DAC's.
                          The 5910 was on display in a show in Honk Kong, and it was roughly 2 times the size of the 3910.
                          I already pre-ordered my 5910.. :B
                          To spend more $$$ on electronics without first addressing room acoustics is fruitless IMO.
                          • Cowanrg
                            • 225
                            got a picture of the 5910? im required to keep my 3910 for a year (denon policy), but after a year, its the 5910 for me!
                              Cowanrg, what do you mean about the Denon policy? Are you doing testing and eval for them or something? If I haven't said hi already, I grew up in Castle Rock, CO, and will end back there in the state someday, I'm sure.
                              • LEVESQUE
                                • 344
                                Denon 3910 results at Secrets:
                                http://www.hometheaterhifi.com/cgi-b...h&articles=120
                                There was also the Arcam DV27A and the Denon 1910 in that shoot-out.
                                • Cowanrg
                                  • 225
                                  Chris,
                                  its a policy if you are a dealer. i get it at cost, but i have to keep it a year.
                                  • Sindhu
                                    Using the HDMI port on Denon 3910
                                    by Sindhu
                                    Have heard so much about HDMI so have decided to give it a shot. But .....
                                    I have a Denon 3910 with a HDMI out and my Denon AVR 3805 is not HDMI. So if I connect the TV HDMI port directly to the DVD player for the video and use the denon link (as I do now) to connect to the AVR for Audio -- will...
                                    09 August 2006, 05:34 Wednesday
                                    New favorable review of Zhd
                                    New review out of the Zhd, original review posted HERE...
                                    13 May 2006, 01:13 Saturday
                                    Denon 2900 vs 5900 vs 9000
                                    by Lex
                                    Any comments from those in the know? Curious.
                                    I'm considering the 5900 for it's dual component outputs. How's the video processing compared to the 9000? I noticed the 5900 has Faroudja, vs another chip on the 9000. Is the 5900 actually more recent technology? I think it is, but looking...
                                    27 December 2003, 19:26 Saturday
                                  • sunprairie
                                    Denon 2900 vs. 5900
                                    by sunprairie
                                    I'm going to buy a Denon DVD player and was wondering if someone out there has any experience between the 5900 and 2900? I know it's going to cost me about $400 more for the 5900, but would there be an advantage? I plan on keeping it for a while. I really know nothing about the 5900, but know that the...
                                    23 February 2005, 09:50 Wednesday
                                  • larry_c
                                    denon 3910 to fujitsu plasma via HDMI?
                                    by larry_c
                                    I am having unexpected problems. I connected a denon 3910 to a fujitsu plasma. I used hdmi from the 3910 to the fujitsu plasma and analog audio to the receiver (nad 773). The visuals do not show on the plasma. In the meantime I have used component connection (from 3910 to screen),...
                                    25 March 2005, 08:23 Friday
