Does Denon Suck, or Do I Have Bad Luck
  • markjrho
    • 34
    Back in the early 90's I had a Denon CD changer that I thought crapped out on me way sooner than I though it should have. Ok, its was probably just the changer mechanism, "no bid deal," I thought to myself.
    So, about three years ago when I was looking for a DVD player, I finally selected the Denon 2910 DVD player which was noted for its CD playback as well as multi-channel capabilities in addition to quality video play. All was good....until two nights ago when I popped in a cd. It wouldn't read it. I tried four more cds and nothing. So I put in a DVD, bingo, it played perfectly. Went back to yet another CD and nothing. :M
    So, what's the deal with Denon, they have ticked me off again, and I have no solution to this problem aside from sending it back to get it fixed. But for all the frustration and cost of shipping and fixing the thing, I may as well just look for a new dedicated cd player.
    Any thoughts on Denon, and my dilemma overall?
  • Burke Strickland
    • Sep 2001
    • 3159
    I know that a lot of people "swear by" Denon, claiming performance makes value out of a high price and lot of others who "swear at" Denon for having incredibly arcane (difficult to navigate) menu systems and relatively frequent and costly breakdowns.
    My 3910 was a beast to operate -- too many poorly documented "gotcha" settings that were required to get what should have been very straight forward functions to work, but were located in not-obvious places and sometimes functioned counter-intuitively -- and then, just after the warranty expired, the unit would not recognize CDs (sound familiar)?
    Denon recommended that I send it to them for a $400 laser replacement, with no assurance that would actually fix the problem. I opted to spend that money on an OPPO universal player instead and have not regretted it. (I do regret wasting so much $$$$ on the Denon in the first place). The OPPO operates flawlessly -- "intuitively", sounds great on CDs and DVDs (and produces great picture too) and has long outlasted its warranty period without self destructing.
      If it's under warranty call them up and send it back.
        My own experiences have not been perfect, but pretty good. I'd buy from them again, if I was looking for an affordable consumer-grade product. FWIW, they really seem to be trying in the last few years to make some of their products better and more high-end.
        • markjrho
          • 34
          I understand your point, but after this I'm gun shy now, so I doubt that I'll be buying anything from them any time soon. It a shame because I like the sound that their products produce.
          Dougie, the warranty is the first thing I checked, and its bee over two years so nothings happening there. I think i'm going to just get a dedicated cd player and use the Denon for DVDs as long as it continues to work.
          • George Bellefontaine
            • Jan 2001
            • 7636
            I have a Denon 3801 Receiver that has performed well for me over the past few years. The original remote crapped out on me but everything else still works. I can't speak for the Denon CD or DVD players. The best DVD player I ever owned was the Sony DVP S7700, which now is used as a dedicated CD player. Would I buy another Denon ? Don't know. The only reason I bought the 3801 was due to the fact I could get it wholesale.
            My Homepage!
            • Jeffery C
              Denon DVD 2900 doesn't read Redbook CDs
              by Jeffery C
              Denon DVD 2900 plays SACD and DVD but doesn't recognize many redbook CDs. The display shows "0h00m00s". It plays redbood Cds one time in every ten trials if I am lucky. It also doen't play CD layer in hybrid SACDs by just showing "Loading". Anyone can provide me with some clue?...
              07 October 2005, 11:41 Friday
            • Ossi
              My comparision of RSP 1098 to Denon AVC A1SE+ (AVR5803) (long)
              by Ossi
              So the last 2 days I have been listening intensively to the RSP 1098 and my “old” Denon AVC A1SE+ which is more known as AVR 5800+ (with upgrade) in the US.
              This comparison does only represent personal view of both units side by side. However I thought it might be interesting to let you guys...
              12 June 2004, 18:18 Saturday
            • will1066
              Redbook on Denon 2900 has crapped out
              by will1066
              Normally, I play CDs through my CD player, but today I went to play a CD on the Denon and it won't read it. Tried a bunch of CDs as well as the redbook layer on an SACD, and nothing. It'll either get stuck at "Loading" or result in "No Play."
              Has this happened to...
              16 January 2006, 12:58 Monday
            • Kevin P
              Denon AVR-3805 Mini Review
              by Kevin P
              I have the opportunity to try out a Denon AVR-3805 for a few days. I'll be posting my impressions here.
              Feature Highlights
              The 3805 is loaded. It supports all the latest surround formats, including Dolby ProLogic IIx, DTS ES Discrete/Matrix, DTS 96/24, DTS NEO:6, Dolby...
              08 April 2004, 08:49 Thursday
            • vsarathy
              Trouble Playing DTS 5.1 CDs with RSP-1098 and a CD Player with a Digital Out
              by vsarathy
              I have a few DTS 5.1 CDs and was trying to play them with my Marantz CD player hooked up by coaxial digital connection to the RSP-1098. In this setting, with a digital input, the RSP-1098 ought to be able to detect the DTS bitstream and decode it. But, it does not and all I hear is a loud hiss from...
              09 December 2003, 19:01 Tuesday
