Turntables
  • KahunaCanuck
    • 222
    Nice new setup & TT Nolan!
    Great looking room...Roche makes beautiful stuff...almost bought some a few years ago.
    There are lots of great record shops here...you may want to pick up a record cleaning machine if you buy a lot used...makes it a fun job to do a bunch of cleaning...then sitting down and listening.
    Cheers!
    Mike
    Kahuna's Theatre
    • Nolan B
      • 1792
      Cheers!
      Mike
      Thanks!
      I have thought about a record cleaning machine. I have a cleaning kit, but have been really lucky with records I have already bought. Normally they are mint, and just need a quick brushing with the static brush. I have pretty much told myself to only buy mint or near mint records. Makes the hunt a little more fun, and since original B&O cartridges arent made and hard to come buy I want to take good care of the two i have.
      Last night the plan was to watch movies...but we ended up going through 3 bottles of wine and playing records until 2 am!
      Check this picture out... I have a high rez version im going to get professionally printed to hang above the TT.
      Last edited by theSven; 03 June 2025, 09:14 Tuesday. Reason: Remove broken image link
        • 1913
        Really Nice setup Nolan! I pity the record that see's that old B&O needle and tone arm. :boohoo:
        John unk:
        • Nolan B
          • 1792
          Originally posted by Nolan B
          Thanks!
          It has a S&M type of look and feel to it. A mid evil torture device for a record. It would be interesting to give something like that a try to hear it, and see the immediate effect it had on a record. One ting is for sure there is no way you would ever have to replace the cartridge because of using an imperfect LP.
          • btf1980
            • Aug 2007
            • 705
            I wondered about that, but I face north so no direct sunlight, and they are always cool because the airconditioning vents are right above them. Do you still think I should move them?
            I would still move them. Records should be stored in a sturdy rack regardless. Plus that little nook will fill up quicker than you know it. 8)
            • wrekkah
              turntables
              by wrekkah
              Just wondering if anyone out there has hooked up a turntable to their Rotel preamp or receiver. What are you using for a phono stage? What is your opinion of your vinyl sound.
              Any recommendations on turntables. Hoping to stay under $1k for the turntable (cartridge & tonearm), phono...
              03 April 2006, 11:56 Monday
            • InTheRed
              Phono ground work around??
              by InTheRed
              I'm looking hard at getting a 1068/1075 combo and had a few questions before I take the plunge.
              It seems the 1068 (and most of Rotel's centerpieces) does not have a phono input and, more specifically, a phono ground. Unfortunately, the cables from my turntable are hardwired and have a...
              08 March 2004, 12:39 Monday
            • thehillboys
              Vintage Bang and Olufsen Recycle build
              by thehillboys
              Objective:
              Well I am itching for a build and have these lying around and want to do something with them. The surrounds on the drivers are shot, and the crossover parts are 40 years old. I am thinking of reusing the cabinets and building a 3-way or something that will go down fairly low. I will...
              26 October 2020, 17:20 Monday
            • John Holmes
              Phono Needles
              by John Holmes
              Does anyone know the average life of the needle on turntables? And when you can tell that you need one? I could use some help.
              09 October 2000, 10:57 Monday
            • Blues
              RSX 1065 & Turntables
              by Blues
              Greetings!
              Has anyone had any success, or tried to use a turntable with the 1065? The unit does not have any Phono connections, so I tried hooking into the Tape inputs(as they are analog), but barely get any sound coming out of the speakers with vol turned way up. Using a Gemini XL-500...
              03 February 2011, 13:01 Thursday
