New Sony Blu Ray Players
  • georgev
    • 365
    Originally posted by maseline_98
    so s550 supposedly comes out tomorrow.....who's getting one? and can you guys give a review who does...
    So, is it out? Anyone got it yet?
    • Blindamood
      • Sep 2003
      • 900
      The BDP-S550 is out now...here is a link to a review, which primarily compares it to the 1st gen BDP-S1.
      Brad
      • chasw98
        • 1360
        Got mine last Wednesday. Was able to buy it from a store in LA for less than $250.00 and it works great. I have not done any more than watch one movie (New Indiana Jones) for now, but I can tell you more when I get home next week. I also have HD DVD unit to compare with.
        Chuck
        • M.Roberts8
          • 229
          I just snagged a 550 last week for 249.99 from sonystyle . You have to apply for the sony card and you get a 150.00 credit off.
          I'm using mine with a ancient Denon AVR-3300 that has served me well for nearly a decade. Using the analog outs was a pain since to call the manual vague is being generous. I finally got it to display the DTS-HD tracks. I just need to do a calibrate/level match it. It sounds great but I have to turn my volume up higher than before I believe it to be a level matching issue.
          Overall I really like it I just got it to share the load. My ps3 is about to hit gaming overdrive with Resistance 2 (8 player online co-op), Little Big Planet and Farcry 2
          • maseline_98
            • 317
            s550 is $329 at amazon with a free copy of Transformers
            bd55 is $332 at amazon now(there is a link to $100 off, but it doesn't seem to work the player).
            Does anybody know where I can pick up a quality 7.1 multichannel analog cable? I guess I could always just run separate RCAs, but that seems messy...
            Sony kds-60a2000\Panasonic BD-55k\XBOX 360 Premium(20gig)Slingbox\Xbox(flashed) running XBMC
            Emotiva UMC-1\Emotiva XPA-5\Klipsch (2)RF-7s with DeanG xover upgrade, RC-7 with DeanG xover upgrade, (2)RS-7s\SVS 20-39PC+
            _____________________________
            “Insanity: doing the same thing over and over again and expecting different results.” - Einstein
              • 16120
              The S350 is going to be like 180 bucks I think it was on black Friday at Sears.
                • 3815
                -Chuck
                • wettou
                  • 3398
                  Bdp-s550
                  How annoying after you open the tray and put a disc in instead of being able to press play and have the player start you have to actually push close and then play!!!
                  I am not sure if I am going to keep this poppy also I spoke with Sony tech support and now I am totally confused.
                  What Sony mentioned is that unless you have a pre/pro or recivers that can decode Dolby Tru HD and DTS Master Audio it doesn't matter if your player can decode these format you will only get downconverted sound to DD and DTS???
                  So who is right?
                    • 3815
                    The button is a trivial thing, but it does show their style of software development. Could be a red flag right there.
                    -Chuck
                      • 16120
                      No that's not correct. If your player can decode them (the S550 can decode both) and output them as PCM and your receiver/pre can accept LPCM over HDMI then your set. It does not convert it to anything it just outputs it to the speakers. Sony tech support is very wrong Now if your receiver doesn't accept LPCM over HDMI then yes it will just down conver to DD or DTS or won't accept the signal at all until you select one of those on the disc.
                      • maseline_98
                        • 317
                        nice....lol
                        • wettou
                          • 3398
                          My receiver doesn't have HDMi but has multichannel analogue would I still get DD tru HD and DTS MA?
                          • Blindamood
                            • Sep 2003
                            • 900
                            Yes. The only reason you'd be limited to the core formats is over coaxial/toslink digital connections.
                            Brad
                            • wettou
                              • 3398
                              Interesting how can multichannel analogue pass uncompressed sound and coaxial/toslink digital can't?
                                • 16120
                                They don't have the bandwidth to pass the raw stream. If your passing over multichannel 7.1 outputs then its already decoded.
                                • littlesaint
                                  • 824
                                  The Panny BD35 is <$275 w/free shipping at Amazon.
                                  Santino
                                  • wettou
                                    • 3398
                                    Interesting I thought RCA didn't have much band width I guess 7 of them do the trick?
                                    • Kal Rubinson
                                      • 2109
                                      The difference is due mostly to legal issues, not technical ones.
                                      Kal
                                      Kal Rubinson
                                      "Music in the Round"
                                      • wettou
                                        • 3398
                                        The difference is due mostly to legal issues, not technical ones. Kal
                                        I thought there were limitations in bandwidth with Digital Optical or Coax?
                                        • littlesaint
                                          • 824
                                          Optical and coax have plenty of bandwidth. It's the SPDIF interface that is limited.
                                          Santino
                                            • 3815
                                            aka "S(ony)P(hilips)DIF" if that helps understand the legal issue
                                            -Chuck
                                            • wettou
                                              • 3398
                                              I see copy protection again, Kal Why do you keep saying that the BDP-S550 doesn't decode DTS Master Audio??
                                              • Kal Rubinson
                                                • 2109
                                                Did I? Where?
                                                Kal
                                                Kal Rubinson
                                                • wettou
                                                  • 3398
                                                  Did I? Where?
                                                  Kal
                                                  may be it was an other Kal, no worries mate
                                                  • littlesaint
                                                    • 824
                                                    There's been some talk that the way the spec sheet for the new Sonys reads, it looked as if DTS-HD MA was not decoded. I think this has since been proven false, but I can't say that with any certainty. Internet whispers is all I know.
                                                    Santino
                                                      • 16120
                                                      The website says the S550 decodes DTS-HD MA and True HD. The S350 will only decode Dolby True HD. I'm a bit curious as to why there are so many players that support internal decoding of True HD and not DTS-HD MA. Is the licensing cheaper or something?
                                                      • Kal Rubinson
                                                        • 2109
                                                        The internal processing is more complex, as is the qualification process.
                                                        Kal
                                                        Kal Rubinson
                                                        • wettou
                                                          • 3398
                                                          The internal processing is more complex, as is the qualification process. Kal
                                                          Interesting Kal when are you going to review the SSP-800 I really would like to hear your honest opinion?
                                                          • Kal Rubinson
                                                            • 2109
                                                            Dunno. They have not yet sent one to me.
                                                            Kal
                                                            Kal Rubinson
                                                            • wettou
                                                              • 3398
                                                              Dunno. They have not yet sent one to me. Kal
                                                              Any time soon, I hope?
                                                              • Blindamood
        • Sep 2003
        • 900
        Speaking of new Sony blu-ray players, they are now shipping the baddest of them all, the BDP-S5000ES. Good news is that it appears to have everything (okay, except DVD-A/SACD)...bad news is that $1999 is the price of admission. Will have to start saving my pennies...
        Here's a link to a Polish web site (hdtvpolska.com) that does an in-depth review of the player and its components (with some parts in English).
        Brad
        • wettou
        • 3398
        THe new Oppo will do SACD and everything else so it might be wise to wait:B
        • wettou
        • 3398
        The new Oppo will do SACD and everything else so it might be wise to wait.
        Also you will find Sony discounted 30% in a few months:B
        Whoa in this review they mean business they took it apart entirely to bad it is not all in english
        • Kal Rubinson
        • 2109
        Just notified to expect it in December. Add 30-60 days for assessment/writing and another 60 for publication lead time and you should see the review by next Spring. :Z
        Kal
        Kal Rubinson
        • wettou
        • 3398
        Just notified to expect it in December. Add 30-60 days for assessment/writing and another 60 for publication lead time and you should see the review by next Spring. :Z Kal
        Whoa that long, :cry: by then who knows maybe Classé might will finally have released the new DSP chip with the new codec decoding capabilities? :lol:
        • Kal Rubinson
        • 2109
        Could be. It is Stereophile policy to favor thoroughness over getting the scoop. While that may still work fine for traditional stereo products that are the mainstay of the magazine, it does mean that, in the faster moving market for multichannel, I will be a little behind the media outlets. So be it. :later:
        Kal Rubinson
        • wettou
        • 3398
        THOROUGHNESS IS GOOD that way no stones left unturned :T
        • georgev
        • 365
        Waiting eagerly for the Oppo(almost certain to get one), but am considering the 550 for the meantime.
        Sony here say they have it in stock but the dealers don't have it. Very frustrating.
        • wettou
        • 3398
        Waiting eagerly for the Oppo(almost certain to get one), but am considering the 550 for the meantime. Sony here say they have it in stock but the dealers don't have it. Very frustrating.
        Amazon.co $329 and 30 days moneyback guarantee:B
        • maseline_98
        • 317
        I wonder if Black Friday is going to bring me a better deal than BD-55(or s500 or BP-2500) with 4 movies(Superman Returns, Batman Begins, I Am Legend, and Blood) for $310 shipped....I'm still leaning towards the panny though.
        • wettou
        • 3398
        Unlikely, but who knows they are trying to stimulate consumers to go out and spend money
        • wettou
        • 3398
        The Sony S550 has delivered the goods great Audio and Video watch queen Blu Ra Concert at Montreal amazing sound and picture
        • maseline_98
        • 317
        I ordered the panny from amazon(it should be here tomorrow). I'm finally blu....
        • George Bellefontaine
        • Jan 2001
        • 7636
        The 35 or the 55 ?
        My Homepage!
        • maseline_98
        • 317
        55 ....I still need to pick up some good analog cables...do you know where I can get some inexpensive(non-monster) cables?
        • oxcartdriver
        HDMI connectivity problem, Integra DTC 9.8 w/ Sony BDP-s350
        by oxcartdriver
        I'm having connectivity problems with my Integra DTC 9.8 and Sony BDP-S350 using an HDMI connection.
        S350 is setup as DVD, HDMI input #2
        Comcast box setup as CBL/Sat, HDMI input #1
        Signature:
        Sony BDP-S350 will not show video or voice when connected through...
        28 July 2008, 13:23 Monday
        Upcoming Blu-ray purchases
        by impala454
        Given this list of upcoming Blu-ray titles (currently announced anyhow), how many of these will you purchase?
        7 Seconds
        A Black and White Night
        Action Starter Pack
        Actiongirls.Com 4
        Afro Samurai Season One
        Alps
        Animalia: Welcome to the Kingdom...
        Zero, I do not own a Blu-ray player.
        20.83%
        5
        Zero, I own a Blu-ray player.
        12.50%
        3
        1-5
        20.83%
        5
        6-10
        25.00%
        6
        11-20
        12.50%
        3
        > 20
        8.33%
        2
        03 July 2008, 16:54 Thursday
        • tallcool1
        Blu-ray vs upconverted DVD
        by tallcool1
        I am wondering why I don't see any picture quality difference between blu-ray and my old upconverted DVDs. For DVD, I have a Denon using SDI to pass the video to my Lumagen scaler which upconverts it to 1080I and sends it via RGBHV to my 73 inch mitsu TV (1080I is max for my TV). Now I have the Sony...
        29 December 2008, 12:13 Monday
        • JeremyG
        Blu-ray LFE output
        by JeremyG
        Hello all, long time lurker first time poster. Great forum!
        I have a question regarding Blu-ray HD codecs' LFE output level. I have a Sony BDP-S550 hooked up via analog outputs to a Marantz SR7001. The Marantz does not decode HD audio. Standard DTS and DD decoded through the Marantz bitstreamed...
        03 February 2009, 23:18 Tuesday
        • debv1947
        Need advice on connections
        by debv1947
        Hello and first let me apologize for my ignorance. I have a question about my new equipment and how it was connected. There is no problem but I don't know if it is connected in the best way and Sony tech support was noncommittal.
        I have a Sony KDL-46XBR8 TV, a Sony Blue Ray BDP-S550...
        19 November 2008, 12:28 Wednesday
