A little experimentation goes a long way
  • George Bellefontaine
    • Jan 2001
    • 7636
    I have two subs in my system, and though I have been relatively happy with how they had been located, I decided to try moving them around a bit. The sub up front was located between the center and right front speakers, and the rear sub was located on the back right wall, about a quarter way to the center. As I said, this seemed to be working okay, but I always had the feeling I was getting some cancellation in the push and pull between the two subs. So yesterday I tried moving the front sub to a quarter position up the front right wall. Well, all I can say is, WOW. In fact I had to do some recalibrating as the bass was just too overpowering. Now it is absolutely divine. End of experiment.
    Has anyone else tried improving their bass by experimenting with placement ?
    My Homepage!
    My Homepage!
  • Kevin P
    • 10812
    I've heard sub placement is key, and proper placement can compensate for a lot of things that are commonly blamed on "the room"--humps, nulls, things like that.
    I would experiment if I had more flexibility in my room in terms of places to put my sub. Instead, I have to settle for a corner placement and a BFD to tame the humps. :roll:
    KJP
    My HT Site
    • John Holmes
      • 2707
      This is one of the things that I think all in this hobby can agree on. Sub placement usually takes work. And once you get the right spot, the rewards are flooring to say the least. And as Kevin stated, there are a lot of us that just don't have the room to play with it as much as we may like.
      I'm glad that you found the time and patience, to reap the rewards you now enjoy. I think that the audio industry would be in a world of hurt if more people invested more time in there actual speaker placement and room treatment. Enjoy!
        • Jan 2001
        • 7636
        I had been aware of how important sub placement was. When I was using one sub I had it placed in the front right corner. Wow, what a BOOM. Trouble was it was too much of a boom. Voices were chesty and bass in general was over-pronounced. When I moved it to ther center position and mated it with a rear sub, I thought I had found Nirvana, but I later felt that although good, it should be better. That's when I tried the quarter way up the right wall. Now it just seems tighter, cleaner and right for the sweetspot.
        My Homepage!
        My Homepage!
        • John Holmes
          • 2707
          George,
          I knew exactly what you meant. Maybe I did not explain well enough.
          I too have thought that it was as good as it could get. Then oneday, just decided to attempt to tweak it a little more and like you, a new level of enjoyment was found.
          Anyway, glad it worked out for ya!
            • Jan 2001
            • 7636
            Thanks, John. Got a feeling many others have done the same thing with the same results. Thing is, many are like Kevin who do not have the flexibilty to change things around.
            Last night a tried out a few soundtracks with a lot of bass and it was like hearing them for the first time. Even in the old position, U571 would shake my pantleg and cause me some concern about the foundation, but when I played it last night, well, it scared the livin' heck outta me. I also played Star Wars Attack Of The Clones for the first time and the low end in that film is a real treat and a torture test for your system.
            My Homepage!
            My Homepage!
            • Ted
              Rotel RLC-1040 or Amp Placement on Sub
              by Ted
              I think I know the answer already, but on a slight hope, I thought I'd ask anyway. ops:
              I am running out of room on my TV stand and was wondering if there would be any harm in placing either a Rotel RLC-1040 or an Amp (either a RMB-1075 or 1085) on top of my sub. The sub is fairly...
              30 December 2007, 14:31 Sunday
            • vinceb
              Sub Placement and multiple subs (graphs)
              by vinceb
              After reconnecting my HE15 I have done a little experimentation with different placements and found that there is a lot to gain in my room from separating the subs. I found good interesting information on the web, specifically Nousaine's work on multiple subs and even better the Harman paper. My...
              07 March 2009, 21:31 Saturday
              Exploring Common DIY Terminology - Imaging
              by technodanvan
              Imaging
              Imaging refers to the ability of a speaker system to create a realistic and accurate soundstage, where the listener perceives the sound originating from specific locations within the listening environment. It is a crucial aspect of audio reproduction that aims to replicate the spatial qualities of the original sound source. Good imaging is essential for providing a sense of depth, width, and height to the audio presentation. When a speaker system has excellent imaging, it can...
              19 July 2023, 09:49 Wednesday
            • Karma
              Dual ASW-800 Subwoofers for my 805 system; What do you think?
              by Karma
              HI All,
              Now that subwoofers can be found in many sound systems, I am curious if any of you use two. Please add your observations about dual subs to this thread.
              Let me offer some background. My first system with subs was in 1976. This was a system based upon the Dahlquest DQ-10...
              16 December 2005, 10:19 Friday
            • cngbrick
              Recommended on-wall build to match IB sub
              by cngbrick
              Good day gents!
              I have been lurking for some time and sorting through the many impressive build threads on this site. I'm impressed with the quality of the information and general tone of the discussions.
              This said, I am looking for some recommendations for an on-wall build...
              16 March 2011, 11:50 Wednesday
