Sorry - I just posted this in Audio Hideout where I think its more appropriate - this can be deleted.
just started wondering about a few things related to 2 channel situations and powered subwoofers.
1. For those that are into 2 channel or hyrid HT/2 channel, how often do you use a subwoofer if at all?
2. Does listening to vinyl lend itself to having a subwoofer whatsoever?
3. I can say through my extensive use of 2 channel CDs, that I find that some recordings are better just using the two main speakers, while other stuff, espicially live for some some reason, I like to fill the room with more bass. Is this the norm?
4. So, if you have some 2channel separates, and want to use your powered sub (if used at all), then how do you do that. What connections, pieces are involved?
