Triggers!?
  • Clive
    Former Moderator
    • Jan 2002
    • 919
    Triggers!?
    Could someone explain about "12 volt triggers" what it does and how important it might be for a purchase decision? I know I lack knowledge but it's why I'm here.
    Thanks!
    CLIVE
    CLIVE
  • brucek
    HTG Expert
    • 303
    UC,
    Generally, triggers are used to turn on power amplifiers whenever your preamp or processor is turned on. This is a simple convenience so you don't have to get up and press the power on switch on your power amp(s) when you switch on your processor with a remote. Some processors have both an "always on" and a programmable trigger output, such that it is on or off depending on the source you have selected. This, for example, allows you to have your mains amp always power up, but your rear and center amps power off when you want two channel for CD.
    12 volts DC has become a bit of a standard, but it would be wise to check that the power amp and processor you are considering have compatible triggers. The processor will usually supply a 12vDC trigger that can source up to a spec'd current capability.
    Usually the power amp trigger input won't draw much current, so this isn't really an issue unless you're trying to trigger many multiple devices. Some power amps will accept a wide range of trigger types. My amps will accept AC or DC triggers from 4 to 12volts. Some will only accept a 12volt DC trigger.
    The usual problem with triggers isn't their voltage, but the connector types. Every manufacturer has their own way of doing it. Some use bare wire terminals, some use mini plugs etc. This isn't anything to deter you from purchasing a particular unit though. You can always adapt to any connector type. Since there is very little current drawn, the wire type isn't significant - any hookup wire will suffice..
    Most amps and processors have the trigger specs listed in their on line manuals.....
    brucek
    • Burke Strickland
      • Sep 2001
      • 3159
      The 12 volt triggers allow separate components to be switched on together, rather than having to use separate remote commands to turn them on individually. Or, in the case of components like a power amp lacking a remote (but including a 12 volt trigger), it avoids having to manually switch the amp on and off every time you use the system.
      It is an operating convenience which makes control of the system more "user friendly", but if you are someone who leaves their power amp(s) on 24/7, it would be of no use to you for the amp(s).
      One thing to watch out for is the signal power rating of the triggers -- some pre/pros have 12 volt trigger outputs that send a signal too weak to trip the trigger on the other component(s). (The user manuals on the manufacturers' web sites should have information about the specs for their units.)
      Good luck!
      Burke
        • 27460
        How's that Clive? 2 good answers within 3 minutes of each other. Burke's tend to take a little longer as he's generally quite wordy, lol. That's why he didn't know it had been answered pretty well. It's a timing thing.
        I would guess that Burke read your message and pressed reply to, then Bruce hit post of his message that was typed.
        Here I always thought Trigger was the Lone Ranger's hoss. :LOL: I am happy to hear what Trigger really is. Neheheheh.
        Lex
        • Steve Goff
          • Feb 2002
          • 186
          Triggers can also be used in other situations. For instance, a video processor may have a trigger to bring down a screen for a front projector, or a trigger that can be programmed to work when the video processor changes aspect ratios, so as to change the masking on a variable-aspect-ratio screen.
          Steve Goff
          Steve Goff
            • 27460
            Great point Steve.
            On a more serious note, I use triggers from my Lexicon MC-1 to trigger both a Panamax unit, and 2 proceed amps.
            Lex triggers Panamax, Panamax triggers amp1, and amp1 triggers amp2. Actually, i may have the MC-1 trigger split, going to amp1 and panamax. Just can't recall.
            I tried to trigger my Parasound 1500A in this sequence, but I just can't get that one to work. I don't know why. Maybe it's 5 volt, instead of 12...
            Lex
            • Uncle Clive
              Former Moderator
              • Jan 2002
              • 919
              Thanks guys, that info is worth a lot. I will be sure to question this feature when purchasing. Wow, thanks alot guys!!
              CLIVE
              CLIVE
                • 16153
                Trigger? Wasn't that Roy Roger's horse?
                • Lonewolf
                  RSP-1066 12 volt trigger splittable??
                  by Lonewolf
                  Hi all,
                  Just got a query, i have a Rotel RSP-1066 and i am currently using its 2 12volt triggers for 2 power amps and i just got a third power amp. I was just wondering if i can use a 3.5mm splitter to have 2 3.5mm cables coming out of one 12 volt trigger so i can have all 3 power amps...
                  22 July 2005, 19:02 Friday
                • probeski
                  trigger power amps always on?
                  by probeski
                  I wish to use the receiver as a switch for my various stereo rca connections to my tv speakers, I will be selecting the stereo rcas as the output into my TV speakers for general TV viewing. If I have triggers connected from my receiver to my power amps AFAIK they will still be turned on but since the...
                  18 November 2007, 02:54 Sunday
                • Shockabuku
                  Rotel 1056 or Denon 3805 with power amps?
                  by Shockabuku
                  Hi @. I also posted this on the AVS Forum (hope that isn't bad form!), but I'd be really interested in the views of Rotel fans (maybe not so impartial though :W )
                  I'm in the market for a receiver & after some demos have narrowed the choice down to the Denon 3805 or Rotel 1056....
                  21 July 2004, 03:52 Wednesday
                • rlin
                  Differences in How Power Amps Sound
                  by rlin
                  I am not sure this is the right forum to bring up this subject but since I am using the RSP-1098 I just want to know other people's experiences...
                  The RSP-1098 is my first true venture into separates...before I was using a Denon receiver as a Pre-Amp and a Carver 705 THX 5 Channel power...
                  25 August 2003, 23:27 Monday
                • ac81017
                  I need new power amps!!
                  by ac81017
                  I´m going to buy a pair of 805s, but I need to upgrade by adding on two power amps! I have a Sony strdb 1070 QS surround amp! YES YES, have a good laugh!
                  oke:
                  Soooo, I won´t have much money at all after I´ve bought the 805s unless I...
                  19 November 2006, 11:43 Sunday
