Differences in How Power Amps Sound
  • rlin
    • 24
    I am not sure this is the right forum to bring up this subject but since I am using the RSP-1098 I just want to know other people's experiences...
    The RSP-1098 is my first true venture into separates...before I was using a Denon receiver as a Pre-Amp and a Carver 705 THX 5 Channel power amp. My front speakers are Vandersteen 2CE (paid only $800 for a used pair). Now since upgrading the preamp to the RSP-1098 its DAC is such a much higher quality that allows me to hear differences in equipments that I did not notice before.
    I decided to try out the new Outlaw 7100 (100x7 channels) power amp given its bang-for-the-buck. Since it is a brand new model, costing twice as the Carver ($799 vs. $399 - I picked up the Carver as a store demo at Circuit City 3 years ago), I would expect the Outlaw to be much superior to the good-old Carver.
    Boy was I wrong. First of all, through the RSP-1098, the power amps sound noticeably different. The Carver has a deeper sound stage, a more sense of air (brighter perhaps?) - a good match to the Vandy 2CE which is not known to be bright sounding. The Outlaw 7100 sounds slightly more forward, a tad less airy (or less bright?), but little more precision in localization of instruments. Given that the Outlaw 7100 is more expensive and already has several positive reviews, I was expecting to like it more, but somehow I just like the cheaper, older Carver sound better. Perhaps it is how well each amp interact with the speakers?
    I would like to hear other people's experience in choosing power amps. I came to the conclusion that it is impossible to test a poweramp in the store unless that particular store has the exact same preamp and speaker setup as home.
    Eventually I do hope to try out the Rotel 1075 though... : )
    Rob
    • 16478
    I'm not the least surprised to hear you hear a difference in the power amps and don't let price fool you there's some very nice amps that don't cost as much as some of the "big" names out there. I think given your tastes you'd really like Rotels 1075 since to me its much more open sounding then my older HK PA5800 amp.
    • Azeke
      • Mar 2003
      • 2123
      Rob,
      I just realized you are in Centreville also, as well as EJ, we should get together a compare notes (okay serparate forum).
      I would go to Myer-Emco, they allow you to test equipment in your home with a 30 day return policy (I believe), but for the most part it all depends on your listening pleasures. Perhaps you, EJ, and myself could meet a Myer-Emco and discuss the possibilites. (Any thoughts EJ?)
      I love my RMB-1095 (just digressing here).
      Let your own ears be the judge. but you should listen in your home environment for the best results.
      Azeke
        • 16478
        sounds like a gathering of the rotel clan
        • dave
          • 434
          Rlin: I am running the rsp1066 which is lower in sound quality than your 1098, and for amplification Tthe rmb1095 with vandersteen 3s&2s and the sound quality is beautiful. I can only imagine what its going to sound like when I upgrade to the rsp1098! My advice would be to do as I did & let your ears make your decision for you. Good Luck
          dave
          Dave...
          • skipm
            • Jun 2003
            • 198
            Just came across this on another forum that may help Rob answer his question and is very good news for all Rotelians. Take a look at the post by "Tom_Bombadil" about half way down the page concerning double blind tests and Rotel amps. Makes you want to go home and hug your 1075/1095.
            -Skip
            • Danbry39
              • Sep 2002
              • 1584
              Well, when I got into home theater 1 1/2 to 2 years ago, I bought an Onkyo receiver, based on my past experiences which had been very positive. I also bought Klipsch reference speakers and the pairing of the two wasn't all that good. At that point, I didn't even know that forums like this existed, but when I discovered them I started researching which amps might sound best with Klipsch. Parasound, HK, and Rotel came up quite frequently, so, when I saw brand new Parasound amps being auctioned off from an authorized Parasound dealer, Ubid.com, I got my 1205A for the bargain price of $649. What a transformation!!! It completely changed my system! It wasn't that the Parasound offered more power, which it did substantially, the Klipsch have a sensitivity of 97 decibels, but that it was cleaner power. Since then, I'll never doubt that power sources can make a substantial difference in sound, even at the same wattage.
              While everything was improved substantially with the Parasound, including two-channel, the final pieces that brought me to my current state of very high satisfaction with music were my Rotel 1066, a Magenta ADE-24 Digital enhancer, and Quantum audio interconnects. All three add up to a great sounding musical experience, especially with my new ACI speakers.
              It all started with the power amp though.
              In fact, when Andrew got his new 1098 and his new Rotel power amp, I knew that the Rotel amp was also part of the improvement in sound that he was experiencing. A well designed power amp is a great addition to any system.
              Keith
              Keith
              • apilon
                Unable to get sound from subwoofer from BFD
                by apilon
                Good Evening all
                First my equipement: i have the Outlaw 7100/950 combo, a paradigm PS-1200 sub a sony amplifier to drive my bass shaker.
                Now here how i hooked up the BFD. I ran a cable from the line input of the sub to the output of the BFD with a 1/4 mono plug. Ran another...
                27 August 2004, 12:50 Friday
              • sarsi
                RSP1098, PS3 and Full HD 3D Playback
                by sarsi
                I like to share some of recent experience with my new 3D TV setup with my current Rotel RSP1098/RMB1095 setup. I am hoping this information is useful for anyone with the same configuration out there that are interested to take the 3D plunge.
                I had not been very active in the last couple...
                19 January 2011, 09:03 Wednesday
              • timjclark
                Need help choosing new pre/pro - rsp1098/outlaw990/???
                by timjclark
                Hello, I need some input on selecting a preamp/processor for my home theater system. I have a merged 2-channel/home theater setup right now. Here is my current gear:
                - HK AVR430
                - PS3 80GB, Comcast HD Cable, Yamaha DVD player
                - Proceed PRE, PDP and CDD, AMP2
                - B&W 640's,...
                20 April 2009, 13:40 Monday
              • soundhound
                Rotel vs Carver
                by soundhound
                Howdy folks, I am new to this forum thanks to the gentleman I just purchased my RMB-1075 from. I was using a Carver TFM-35X to run my fronts- Klipsch RF-3's, as my primary concern has been 2 chnl audio. I use a Rotel RSP-980, RDA-980, and RDA-985. I also am running the full compliment of Klipsch Reference...
                19 March 2004, 19:56 Friday
              • J.H.
                7100 To A C2?
                by J.H.
                I recently purchased a 7100 controller and love it but as all us crazy HT people are I'm wondering what is the difference between the 7100 and the C2? Would it be an enormous difference in sound quality? Or to get an enormous difference i would have to go to the C1? I am curious because a friend asked...
                14 November 2005, 16:59 Monday
