I wish to use the receiver as a switch for my various stereo rca connections to my tv speakers, I will be selecting the stereo rcas as the output into my TV speakers for general TV viewing. If I have triggers connected from my receiver to my power amps AFAIK they will still be turned on but since the stereo RCA output will be selected will my power amps be on but not active? Do power amps draw more or less power like this compared to standby mode or actual usage; will this type of use reduce their life? The reason I might use this setup is because the power amps are in a different room.
trigger power amps always on?
Yesthey will still be turned on but since the stereo RCA output will be selected will my power amps be on but not active?
Amps that respond to a trigger are in a stand-by mode unless they're unplugged or there's a real power switch on the back of the amp.Do power amps draw more or less power like this compared to standby mode or actual usage; will this type of use reduce their life?
My Ayre V-5 amps have such since there's an on/off switch on the back of the chassis. With that switch in the 'off' position there nothing powered up in the amp. When the rear switch is 'on' there's a pseudo power switch on the front of the chassis that toggles the amps from stand-by to on.
Sitting in stand-by mode has minimal impact on the life expectancy of an amp.
I am considering Halcro MC20 and MC30 amps I wish to know if it is okay for Class D amps to be powerded on for lengthy periods but not actually used to drive speakers . I need the receiver as a switch when using the TV speakers but i also need the Halcro's to be triggered as they are in another room and don't have a remote. AFAIK Class D amps are more efficient and should draw less power but they are also expensive high end amps and am concerned that i will reduce their working life, any opinions?- Bottom
by briandxI'm trying to set up my 1066 to trigger my two amps on when the 1066 is fully on. I've followed the instructions to do this, and when I put the 1066 in Standby, I do hear some clicking from the amps.
However, the power buttons are still illuminated on the amps, so I can't tell if the...-
Channel: Club Rotel
by pianorobHi,
I have a CAp2100 since November. Sound is great, but I have problem with the fuse of the standby-power supply and would like to ask whether anyone had similar problems:
when I switch off the power button, then disconnect the power cord (e.g. to
replace it with...-
Channel: Club Classé
20 January 2008, 08:43 Sunday -
by JonMarshOnTheBench.key by Jon Hancock, on Flickr
The Cambridge Audio 651W is now my new go-to amplifier for small and portable for speaker measurements. I got spoiled by the Benchmark AHB2- the 651W isn't truly an AHB2 replacement, but it's as close as you have any right to expect...-
Channel: On the Bench and in the System
by chasw98This is a DIY project to build a device that will automatically turn on and off your "pro" amplifier. A lot of people around here have built subwoofers powered by pro amps like Crown, QSC, and Behringer. These pro amps have no way to be turned on or off remotely by either 12VDC or 120VAC "trigger"...-
Channel: Mission Possible DIY
by Pitou2Hello,
I just got a used RSP-1068 and there are some little issues with it. It works fine generally, but I have some questions.
1- The "standby" button doesn't have any effect
2- When I power it on with the back on/off switch, it power on displaying only "zone"...-
Channel: Club Rotel
07 October 2014, 13:21 Tuesday -
- Loading...
- No more items.
