Low profile, wall mounted DVD player
  • Kevin_B
    • 6
    I'm looking for ideas here. :idea:
    I have a 19" LCD mounted on the bedroom wall, and want to hook up a DVD player that's small enough to not get in the way of the small walk area to get to the other side of the bed. Do they make some sort of wall-mount cabinet that opens when you want to use the DVD, or a DVD player that can mount bottom-against-the-wall style?
  • Alloroc
    • 2580
    Well now, I'm not sure of any stand alone players. There are a number of HT in a box kits out there though from all kinds of manufacturers - from cheap to expensive - as in Philips Electronics to Nakamichi and then Bang & Olufsen.
    That's all I got...
    Vincent.
      If you can find one of these, I recommend it: http://www.recommendedbuys.com/elect...arp-sd-px2.htm
      It comes with a wall bracket and it is much better quality than players that come in HTIB's. I have one in my bedroom and use it as a portable also. It doesn't come with speakers (a good thing). It's not in current production, so you'll have to search.
      • Kevin_B
        • 6
        Great post! Exactly what I was imagining!
