Wall-mounted speaker based on the PE Encore?
  • lunchmoney
    • Jul 2008
    • 152
    I'm very much digging the Parts Express Encore design as home theatre mains, due to it's modest size and simplicity, as well as its supposed good performance when close to a wall...
    It uses a .25 cubic foot sealed cabinet, with outer dim's of 12" high X 7.5" wide X 10" deep.
    What I'm wondering is if I can make a wall mounted version, using the same drivers, same crossover design, same distance between the drivers, and same internal volume... but a different shape which allows it to be close to the wall (taller, wider, and not as deep) and angled inwards...
    Will this result in a similar speaker? Or will the different shape screw it up?
    Last edited by theSven; 27 June 2023, 19:44 Tuesday. Reason: Update image location
    You can make the baffle taller not wider
    • lunchmoney
      • Jul 2008
      • 152
      Do you mean that I can make it taller without messing things up, but not wider?
      • Mazeroth
        • 422
        No. That's exactly what he didn't mean. :roll:
          Yes..
          You might read this thread. In post Music and Instruments our Chris D (aka CJD) makes a crossover for on-wall use..
          • lunchmoney
            • Jul 2008
            • 152
            Anything useful to contribute?
