No DTS from Denon-link?
  • Rolyasm
    • 382
    My buddy has a Denon 3805. It is hooked up to his DVD by the Denon link. When he puts in DTS material, the receiver won't pick up the signal. When he selects DTS nothing comes out of the speakers. Does he still have to run the analogue cables? I thought Denon Link and those other brands (i-link) took care of all sound and negated further cables. It says it works for SACD and DVDA. Any thoughts? I had him hook up the analogue cables and now he has sound. Is this typical?
    Roly
    Twin Moderator Emeritus
    • 16706
    I would assume it work for DD/DTS as well but perhaps it's only setup to transmit the two high-res audio formats....?
    If nothing else, all he has to connect is a digital coax or optical (toslink) cable to send the DD/DTS signal digitally to the 3805
      He may need to configure the 3805 to allow DTS via DenonLink. Has he read the owner's manual? Admittedly, Denon has the worst written of them all, which doesn't help things.
      • Octavio
        PLIIx Cinema decoding of Dolby Digital 5.1 Sources with Denon AVR 3805. Please Help.
        by Octavio
        I have a problem with my new Receiver, Denon AVR 3805. When I play a DVD encoded with Dolby Digital 5.1 (connected to OPT1 input) and try to use the Surround Back speaker I only get PLIIx Music and can't get PLIIx Cinema as an option. Of course SB Channel is set to on.
        Each time...
        25 May 2004, 07:58 Tuesday
      • Sindhu
        Auto Set-up for Denon 3805
        by Sindhu
        What has been your experience with the auto setup of the Denon AVR3805?
        I did mine on the weekend and oops ! It did the FL/FR/C distances correctly (12.5 ft for FL/FR and 14.5 ft for center) put the sub 21 feet away (shud be 15ft) and the SL/SR 10 feet away (shud be 6 ft) from the listening position....
        13 June 2005, 02:57 Monday
      • Don
        Rotel 1055 vs Denon 3803
        by Don
        I was thinking of getting the rsp 1066 or avr 3803 (pre/pro) and the a rotel amp. Prices in the combo are very close.
        I want the rotel combo but should I be concerned about the burr-brown (24/192) dacs and 24/96 dts that the denon has and not the rotel?
        Thanks.
        17 March 2003, 16:09 Monday
      • Kevin P
        Denon AVR-3805 Mini Review
        by Kevin P
        I have the opportunity to try out a Denon AVR-3805 for a few days. I'll be posting my impressions here.
        Feature Highlights
        The 3805 is loaded. It supports all the latest surround formats, including Dolby ProLogic IIx, DTS ES Discrete/Matrix, DTS 96/24, DTS NEO:6, Dolby...
        08 April 2004, 08:49 Thursday
      • Ossi
        My comparision of RSP 1098 to Denon AVC A1SE+ (AVR5803) (long)
        by Ossi
        So the last 2 days I have been listening intensively to the RSP 1098 and my “old” Denon AVC A1SE+ which is more known as AVR 5800+ (with upgrade) in the US.
        This comparison does only represent personal view of both units side by side. However I thought it might be interesting to let you guys...
        12 June 2004, 18:18 Saturday
