Martin Logans..Need a Receiver
  • Sunzui
    • Mar 2004
    • 6
    All,
    I am looking for some recommendations for a HT receiver to accompany my Martin Logans. I do have a $1,000 budget and the normal HT theater requirements.
    My B&K AVR202 just died recently :cry:
    Thanks ahead of time for the suggestions.
    Sunzui
    Sunzui
  • Aussie Geoff
    • Oct 2003
    • 1914
    Sunzui,
    I'm not aware of ANY receiver that will do justice to a pair of Martin Logan speakers... If you possibly can go listen to some separates like the Rotel RSP-1068 and matching amplifiers...
    That aside - some that will do a acceptable (for a receiver) job include:
    >> Rotel RSX-1067
    >> Arcam AVR300
    An cheaper but not as good:
    >> Denon 3805
    >> Yamaha RX V2400 or RX-V1400
    Geoff
      • 27461
      Yeah, ML speakers, and all electrostat speakers are particularly heavy loads. You'd be served a lot better by separate amps.
      I'm reminded of a time I had a pair of Infinity Kappa 7.1s with 10" woofers. I always thought they sounded pretty good with a 100 watt Rotel amp, RB-985. But then I connected a Proceed HPA-2 @ 250 watts, and WOW did those woofers come to life! Granted, it's not a like comparison comparing driver based speakers with electrostats, but you get the idea of the differences that can occur.
      Lex
      • bhuskins
        • 504
        The only receiver I would recommend for the ML's (loosely) would be the Ultimate Receiver by Sunfire. It has a pretty powerful amp and can do a pretty good job with the ML's.
        I agree though...the right separates will make the ML's sing.
        Brent Huskins
        Media Design
