Using a stereo preamp for HT...help please
  • mark4x4
    • 32
    This is what I'm trying to accomplish. I want to use my front mains for HT and 2 channel stereo. I've been using a Yamaha 2400 A/V receiver for my HT. As my interest in stereo became more apparent, I purchased a Aragon 8008 MKII amp. I'm using the pre outs on my Yamaha for my amp to power my front mains. I know that there are some newer preamps that have a HT pass through which allows the use of my Yamaha for HT using the front mains and then allows you to switch to stereo and still use the front mains.
    I have a chance to buy a Classe stereo preamp from a friend of mine at a geat price. My question......Can I use this stereo preamp for HT without switching cables for my front mains? If I can, how would everything be connected so I can use my front mains for HT and stereo?
    I have a DVD player for HT and a CD player for stereo. MY thought was to set up to two complete systems, one for HT and the other for stereo. I have another set of speakers but they are not near the sound quality of my current front mains.
    I would appreciate any advice in this matter.
    As always thanks in advance.
    mark4x4
  • LikeCoiledSteel
    • 210
    Pre amp w/home theater pass-thru
    Hi Mark,
    I was in the same boat as you when I wanted to use one system for stereo and HT, with high quality 2 channel playback.
    I ended up getting a Krell Kav250p 2-channel pre amp that has a home theater pass thru capability. I use my Outlaw 950 prepro for movies, I feed my main outs from the outlaw into the Krell pass thru. This basically defeats the voume control on the Krell so that the Outlaw can control the volume for all the speakers.
    I use 3 amps in my system:
    Krell Kav250a for mains
    Outlaw M200 for the center
    Adcom GFA535 for my surrounds
    It is a littler cluttered using 2 preamps and 3 amps, plus all the source equipment. But the sound is very good.
    You can use your Yammie for your center and surround speakers, and use the Aragon for your mains. I have heard of some people using an auxilliarry in on there 2 channel pre to get the signal from their receiver or HT pre. But if the 2 channel pre does not have home theater pass thru, then you will have to ballance both volumes.
    Best Regards,
    Jeremy
      • 16178
      Another preamp which supports pass through with fixed gain is the Ayre K5x.
      Many preamps "could" be used in this mode, but the problem would be getting repeatable gain settings for the front mains, as you'd have to set the volume control to a reference point. One way to do this would be to calibrate your levels with your receiver, then run the pre out from the receiver into one of the preamp inputs, and run up the preamp volume until it matches the levels generated for original calibration- then make note of this as the volume setting to use in "HT mode". That's something of a work around, but would expand the selection of preamps you might be able to use. Including your friend's Classe.
      Good luck getting things sorted out to your satisfaction!
      ~Jon
      • Bruce
        • 156
        Mark,
        What John is suggesting is what I've been doing for the last 5 years. I use a Parasound 1100D Stereo Direct preamp for all my 2-channel listening. It's L&R outputs connect to the amps that power my Front main L&R speakers (Dynaudio Contour 2.8 towers). It doesn't have an "HT bypass" or "unity gain" switch.
        I take the L&R preouts of my HT processor (like your Yamaha) to an AUX input on the Parasound preamp.
        I found that the 12 o'clock position of the Parasound preamp's volume control is essentially the unity gain position (i.e. no attenuation or amplification of the source signal). My CD player, TT, and FM tuner are also connected to the Parasound preamp.
        The Parasound preamp's 12 o'clock volume position is where I do the HT processor's speaker calibration for all speakers.
        This way I only have the HT processor and DVD player turned on when watching HT otherwise they are turned off.
        Bruce
        • mark4x4
          • 32
          Thanks for the great information. You guys answered my question and then some.
          I appreciate you guys taking the time to help me out.
          mark4x4
          • mark4x4
            • 32
            I need help again. Is there a way that I can hookup my subwoofer so it can be used for both HT and stereo. I now have my sub hooked up to the LFE output on my receiver which won't enable me to use it in stereo mode and if I use the output on my preamp to sub then I would not have it for HT.
            Any recommendations will be greatly appreciated.
            Thanks in advance,
            mark4x4
            • Bruce
              • 156
              Mark,
              I've been using my sub with my main towers for the last 5 years in the following configuration:
              1) HT Processor L&R preout --> 2-channel preamp L&R AUX input
              2) 2-channel preamp L&R output --> Marchand XM9-L electronic crossover
              3) electronic crossover L&R mains output (high-pass) --> L&R mains amp input
              4) electronic crossover L&R sub output (low-pass) --> L&R powered sub(s) input
              The important note about this Marchand electronic crossover is that it uses 24dB/octave (4th order Linkwitz-Riley) filters, which are relatively steep slopes, in a symmetrical fashion for both the high-pass and low-pass sides of the crossover. This is much different from the setup inside most HT processors.
              This means all signals leaving the 2-channel preamp outputs are split between main speakers and sub(s), i.e. 2-channel and HT both use the sub.
              Note:
              I have the sub's internal crossover turned off, and I have the HT processor's speaker setup configured as follows:
              Mains=Large
              Sub=No (the Sub-output jack on the HT processor is empty)
              center=small
              surrounds=small
              FYI:
              It is a Dolby requirement (sepcification) that all HT processors will re-direct bass from small speakers as well as the LFE bass to the main speakers (set to Large) if Sub=No is specified in the speaker setup menu.
              I might add that I don't need to adjust sub levels between the 2-channel and HT sources, because everything is in balance for my listening position.
              Bruce
                With the exception that my preamp has a by-pass circuit; I use exactly the same arrangement Bruce uses. (this includes use of a Marchand XM9).
                As far as I know this is the only way to solve this problem.
                • mark4x4
                  • 32
                  Thanks, that answers my question.
                  Do you have any idea of how much the Marchand would cost?
                  Thanks again,
                  Mark4x4
                  • mark4x4
                    • 32
                    Disregard my last question. I found the answer. Gotta look before you leap.............
                    • Bruce
                      • 156
                      IIRC, it was ThomasW who pointed me to the Marchand site in the fiirst place about 5 years ago, although it wasn't on this forum (it didn't exist then).
                      Thanks Thomas!!!!
                      Bruce
                      • dixon
                        Is a sonic improvment if I use a stereo pre instead of surround processor?
                        by dixon
                        Hi guys,
                        I nees some advice,opinions here.So if I have a dedicated 2 channel pre(stereo) like RC 1070 or 1090 instead of use rotel rsp 1068 for 2 channel,I will have a better sound in stereo?
                        Second question:Can be integraded the stereo pre(RC-1070 or 1090)in a HT setup,so when listen...
                        09 October 2004, 22:11 Saturday
                      • audiofil
                        ROTEL stereo pre-amplifier RC-1090
                        by audiofil
                        I know this Forum is for the Home Theater, but I want very to know the comments of you for the pre-amplifier of ROTEL RC-1090 (1,800$ CAN)!
                        In the province of Quebec (canada), any stores have this pre-amplifier in stock or demo! Their explications is this product is not so good in comparaison...
                        25 December 2003, 11:01 Thursday
                      • Ross Smith
                        RSP 1068 or Stereo Pre-Amp
                        by Ross Smith
                        At present I have a RSP 1066 and the RB 985 power amp, previously I have owned the RSP 980 and the RSP 976. The 1066 is a nice smooth sounding Pr-Amp but compared with my other pre-amps I find it overly smooth. I would like a bit more bite in the treble region, with DVD's it's fine as it tames down...
                        18 August 2004, 05:16 Wednesday
                      • timjclark
                        Need help choosing new pre/pro - rsp1098/outlaw990/???
                        by timjclark
                        Hello, I need some input on selecting a preamp/processor for my home theater system. I have a merged 2-channel/home theater setup right now. Here is my current gear:
                        - HK AVR430
                        - PS3 80GB, Comcast HD Cable, Yamaha DVD player
                        - Proceed PRE, PDP and CDD, AMP2
                        - B&W 640's,...
                        20 April 2009, 13:40 Monday
                      • pramod
                        Adding Stereo Preamp to Ht Setup
                        by pramod
                        Hello Dear Friends,
                        Please forgive me if this question is a dumb question. I have Rotel RMB 1075 5 channel power amp with RSP 966 5.1 processor. and NAD Pre 162 stereo pre amp. I'm not quite happy with the stereo performance of my RSP 966 in two channel stereo mode. So I'm planning to...
                        24 October 2006, 15:31 Tuesday
