Greetings All,
I had a quick question with regards to the speaker cables. I have the B&W 604 (fronts) 602 (rears) LCR600 (center) and ASW650 (sub) with a Rotel 1067.
I am using this equipment with loaner cables that the dealer has provided and hence I am looking to buy some cables for myself. However, I cannot seem to find any.
The speakers support a bi-wired configuration and I was wondering if a bi-wired cable would work.
Also what should be the gauge and the specs on the cable. I did go over board with the equipment and hence the budget for the cables in rather tight.
I am not brand concious at all, but i do care if the cables are medium to high grade. I guess I am looking for the best bang for the bucks. Any help would be greatly appreciated.
Amit.
Amit.
