I recently noticed a number of sites with instructions for building your own cables from cat5 network cable. My current set up is a Cambridge A1 amp, low-end Mission speakers (can't remember the model off-hand, but they're two-way bookshelf type mounted on stands). My current cables are some no-name "speaker" cables. They're the figure-of-8 type, about 3mm in each core. One core appears to be copper, the other probably steel. There's about 2-3m running to each speaker. Two questions:
- Which core of the cables (copper/steel) should go into which post on the speakers (red/black). Or does it make no difference?
- With this set up, will I notice much difference if I get some better cables, preferably the DIY cat5 or mains lead type?
