Lets talk about Power
  • Dmantis
    • 1037
    OK,
    so my question to the board is what power center and power cords do you guys use?
    Twin Moderator Emeritus
    • 16706
    I use APC Line-R power conditioners http://apc.com/products/family/index.cfm?id=67 and stock power cables as of now, though that's something I'll be upgrading when I get the boss's approval (or I sneak them in :lol: )
    Gonna move this thread though as it's not specifically Rotel related and you'll likey get more responses in HT.
    • ht_addict
      • Dec 2002
      • 509
      Just picked up a Monster AVS 2000 Voltage Regulator to mate with my Monster HTS 5000mkII. No I didn't get caught up on the Monster hype, I was able to trade for the month old 5000mkII for $300CDN and my HTS 1000mkII. The AVS2000 was picked up because the 5000mkII was telling me that the voltage was running from 108v to 115v at any given part of the day. Only late at night would it hit 120v. Also I was able to get it from the dealer I buy everything from for 20% off and no inerest/payments for 14mths.
      Power cables come from a local maker. Their called Silver-1 with the following features:
      Military grade 12AWG silver plated copper conductors with PTFE Teflon insulation. 4 conductors in a star quad configuration, effective 9.5AWG rating.
      1 12 AWG silver plated copper conductor for grounding spiralled in opposite direction of star quad rotation.
      Marinco 8215T Hospital grade 3 prong plug.
      Marinco 320 IEC connector.
      Wire and connectors cryogenically treated at -300F.
      Braided copper shield, grounded at plug end only.
      5 discrete layers of Teflon dielectric.
      EMI/RFI attenuation layer.
      Black Techflex expandable poly sleeve for durability.
      Deray IHKT heatshrink on PC ends.
      Key Benefits
      ht_addict
      • jimmyp58
        • 1449
        I use a combo of sorts. For my major items, I use a BPT BP1/CPC Ultra Power Center and for my 'other' components, I have them connected to a Monster Power Center HTS 5100 (X2). For all my amps, pre/pro, and Denon DVD-5900 I use the BPT L-9 power cords.
        jpiscitello@ameritech.net
        • Azeke
          • Mar 2003
          • 2123
          I currently use the Monster HTS 3500 MkII, which does an efficient job.
          I am also using stock power cords, but will investigate Power cord upgrades in the not to distant future.
          Azeke
          • Glen B
            • 1106
            DIY balanced power unit;
            Acoustic Zen Krakatoa power cords (2 pcs., one retrofitted with Furutech 20 series 15 amp wall and IEC plugs, the other retrofitted with Wattgate 350iHC 20A IEC plug);
            Acoustic Zen Tsunami II power cords (2 pcs.).
            • Dan Schulze
              • Jun 2003
              • 72
              Once I got serious about my power, I first purchased the Monster Power Conditioner HTS 5100. Once I upgraded my amps, I had a need to get a Voltage Stabilizer. I chose the Monster AVS 2000. I currently have not done any upgrade to any of my power cords, still using the stock ones.
              These two items to a great job of maintaining 120v to my system. During the summer months, especially during the day, I have seen my AVS 2000 correct the incoming voltage as much as 10 volts, and I wasn't even driving the system at all. I am glad I bought both these items. I also like being able to see the current usage of my system, which is typically in the 5 to 6 amp range, but cranking the system, will pull upwards to 14 amps!
              Dan
              I want to be SHAKEN not stirred!!
              • Claude D D
                • Jan 2003
                • 465
                I use a Monster HTS5100 and have DIY powercords made from 12 gauge shielded teflon coated Belden 83802 and Marinco hospital grade IEC and 3 prong connectors.It all works great,real low noise floor.
                • CWD
                  • Mar 2004
                  • 22
                  Can I add the following questions to the discussion...
                  I am wrestling with the power issue myself.
                  I can't decide if I should add a power conditioner like the Monster HTS 3500/5100 or something like Richard Gray's Power Company 600S. It would appear that the 600S smooths out the power and cuts the noise level by providing a reservoir to meet demands. I've heard lots of good stuff about units like the 600S and the 400 Mark II.
                  I do get some noise in my HDTV picture that I'm pretty sure is power related. I hear both types of units can make things better. I've also heard that the Richard Gray stuff improves the performance of source devices like DVD players.
                  So...anyone have some experience with these two solutions to help compare and contrast? Anyone have any experience with the Richard Gray Power Company units?
                  Thanks.
                  • G12345567
                    bi-wire and cable choice/length?
                    by G12345567
                    My setup is as follows.
                    Amplifier: Marantz SR5200
                    Centre: LCR60
                    Front L & R: 602s3
                    Rears L & R: 601s3
                    and a 3rd party sub (rca connected)
                    at the moment the fronts and centre are bi-wired using the following grade cable.
                    08 August 2004, 21:32 Sunday
                  • DIY_newbie
                    My balanced power project part I (pictures)
                    by DIY_newbie
                    I got tired of waiting for my repaired ribbon so i could complete my main speaker project so I decided to start working on the quitech transformer in a box.
                    This thing is huge!!! 90lbs and 12" in diameter !!!
                    10 guage OFC wire for internal hot/neutral...
                    08 May 2005, 21:12 Sunday
                  • clm811
                    Premium-grade power cord
                    by clm811
                    Upgraded power cord{AWG16x3C Shielded w/IEC plug} sold in bulk, (identical to that supplied by both Denon and Parasound with their high-end components) It is an audible upgrade to the standard "computer" cords supplied with most components. Marinco and Wattgate plugs are available through...
                    07 November 2002, 19:12 Thursday
                  • Burke Strickland
                    Parasound introduces new Halo JC1+ monoblock power amplifier
                    by Burke Strickland
                    https://parasound.com/jc1+.php
                    Replacing the original John Curl-designed JC1, which was chosen as a “Category A Recommended Component” for 15 years by Stereophile’s editorial staff, Parasound has just introduced the JC1+ monoblock power amplifier, which was also designed...
                    24 January 2020, 22:16 Friday
                  • sonicbaer
                    Power conditioners...??
                    by sonicbaer
                    I know this subject seems to get out of control and I'm not trying to start any trouble...I don't want to be exiled ..I'm just getting started..
                    My dealer was kind enough (I think) to lend me some Transparent power connectors...when I connected them in place of my OEM cables, I think...
                    17 July 2006, 00:20 Monday
