Optical inferiór to RCA ?
  • umasgrad
    • 15
    Hi all,
    I thought this was so simple! optical being digital should be better than analog RCA connector!! Well, seems not to be the case... atleast for stereo listening
    My setup is
    Rotel RSX-1057
    BW 602
    REL STROM V
    Monster Optical interconnect
    Local RCA stereo cable
    sony DVD player DVP-NS575
    I connected the Optical out of my sony DVD player to 1057 and mapped it to DVD. I also connected the Audio line out RCA of the sony to the CD-in of the 1057. AS I listen to different CDs I switched my 1057 inputs between CD and DVD alternatingly. It was very very clear that the RCA connected CD input had an upper edge in terms of clarity. I thought something was wrong with the DSP setting of CD and DVD, but both were on stereo mode (NO DSP). ACtually the difference was very profound on the highs, the RCA (unbranded from super market) had clean highs compared to the optical. Beats me...
    thanks
  • CombatWombat
    • 57
    I never liked optical personaly, Dig coax all the way
    • Snap
      • 1295
      Let me get this straight? You are compairing a Rotel CD player to a Sony DVD player???? Did I miss something here?????
      If I misread your post then I am sorry, but If I got it right redo your test!
      Use both analog and digital out of the SAME CD or DVD player and make your side by side test. Othewise...........
      Well I would be upset if the Rotel did not sound better.
      But that is just my thoughts....
      • umasgrad
        • 15
        I will be disappointed to! No, I am checking the audio quality of the same setup, ROTEL Receiver and SONY DVD player with Optical interconnects vs Stereo RCA interconnect for Music listening.
        • umasgrad
          • 15
          I never tested Coax, may that will be an interesting test.
          I dont know if the problem is
          With SONY Line out vs Optical out quality,
          Rotel Digital Optical in vs Analong in Quality
          or the
          interconnects. I guess I need another DVD player to test.
          • George Bellefontaine
            • Jan 2001
            • 7637
            I go by my ears and honestly, I don't hear a difference between coax and optical.
            My Homepage!
            • Brandon B
              • Jun 2001
              • 2193
              He didn't do that test yet. He connected the analog outputs of the Sony DVD player (RCA) with supermarket cables, and compared to a Toslink connection with the same unit.
              That is kind of weird. Implies the DACs in your Sony DVD player are doing a markedly better job than the ones in the Rotel. Which is possible I guess. Just seems like the Rotel, being pretty new and all, would do a good clean job compared to an older Sony DVD deck.
              Try coax though. Maybe something is up with your optical chain.
              BB
              • umasgrad
                • 15
                I will get the coax and post the result.
                • DrJRapp
                  • Apr 2003
                  • 1204
                  thanks
                  Don't laugh but I read about this on another forum where someone actually had forgotten to remove the little clear plastic protectors from the ends of his toslink optical cable. Everything cleard up wondefully after he figgured that out.
                  Jerry Rappaport
                  • peterS
                    • 1038
                    i had a customer return a reciever because it was "defective"
                    not only had he done that but he shoved the toslink cable in reversed so we couldnt remove the cable w/o pliers... of course he wasnt intrested in us instaling it for him :roll:
                    • Russ L
                      • 544
                      umasgrad- In the manual for my Benchmark DAC1 their engineers recommend using a coaxial cable in over an optical in from my DVD/CD Player because "TOSLINK optical connections work well at sample rates up to 96 kHz but may be unreliable or non-functional at higher sample rates (such as 192 kHz). We suggest using either the XLR or coaxial digital inputs at sample rates above 96kHz". I hope this helps explain the difference you heard. I followed their advice. If you need more info the Benchmark website has a downloadable manual for the DAC1. -Russ
                      Russ
                      • umasgrad
                        • 15
                        I tried out the COAX, RCA, Optical. But First, DrJRapp and PeterS Thank you its a good point. Sometimes in the excitement with the New system and all it is possible to do such things. Luckily I did not do that mistake of either connecting with the wraps or forcing the cable. Here are my results, ofcourse these are subjective...
                        I connected all three cables to different source inputs and alternated between them. The RCA and COAX were great, I could not tell the difference. The optical was not good as either. I conencted the optical to the second optical port on the receiver did not make a difference. I dont know if I have change the cable and try out. Does not matter as long as the COAX works for digital input, I stay with it.
                        • umasgrad
                          • 15
                          What is XLR ? I think I will follow the advice on Coax too!
                            Twin Moderator Emeritus
                            • 16706
                            I generally prefer coax over optical as a good coax is cheaper than a good optical, otherwise their performance shouldn't be dissimilar given equal quality and assuming there's no technical problems with either. Also my guess is that your optical cable is made of plastic and not actual glass fibre which could be some of the difference as well.
                            • Russ L
                              • 544
                              umasgrad- The XLR is for balanced inputs, something I don't have on my Rotel RSX-1057. I think their available on the higher cost amps(or is it CD players?!) which have a balanced or dual amp circuitry for each channel inside of them . Believed to cut down on distortion+ improve SQ. I heard of a Classe Pre-Pro or Amp that has that:?? Out of my league! Mid Grade Equipment like mine doesn't have it so I don't worry. Others will know more than me about balanced XLR interconnections :B .-Russ
                              Russ
                              • umasgrad
                                • 15
                                Then I guess XLR should wait for my home... I just drained my wallet with the Rotel and REL. My wife is already mad : . Anyway I am very happy with the current new set up :W
                                • NonSense
                                  • Nov 2003
                                  • 138
                                  XLR is a balanced type of interconnect using three signals.
                                  1 - Audio Signal
                                  2 - Audio Signal Inverted
                                  3 - common
                                  The advantage is its ability to reject common mode noise. This makes shielding is less of an issue in noisy environments. You also usually get a net 3db signal gain on the TL over a single ended cable. For whatever that is worth.
                                  Some systems are designed to accomodate balanced signals through the entire signal chain. In this situation the manufacturers often recommend taking advantage of this type on interconnect to maximize performance.
                                  Bruce
                                    • 2901
                                    So basically we've concluded that his Sony DVD player's optical output is inferior to the coax and analog connections. I know how that goes!
                                    • jim777
                                      • 831
                                      The only reason one should choose optical over coax is to avoid ground loops in some cases. It does not connect a common signal between components.
                                      Otherwise it implies additionnal circuitry and I'm sure more jitter (because the optical receivers are not calibrated to have the same rise-time and fall-time (0to1 and 1to0) in a given setup).
