A Subwoofer Possessed!!!
  • kmak
    • Dec 2002
    • 1032
    Hi Folks,
    Happy New Year, when do we stop saying that? :scratchhead:
    I have had a bizarre problem, for quite awhile, with my Paradigm Reference Servo 15A (1999). I have a chesterfield next to it and the sub is rear right corner loaded (about 3 feet out).
    Here's the weird part, whenever my cat kneeds on the end (nearest the sub) cushion, or I drape a comforter over the end backrest cushion, the mofo driver moves. I checked the line-in and reconnected, but it still does it. There is no electrical association (ie bass shaker) whatsoever. The current flooring is laminate, and prior to that carpet. In fact, when it was carpeted, the room was set-up differently. I had the sub in the front right corner, with the couch swung around 90 degrees. It did the same thing there, although I kind of ignored it or thought it was something else causing the crackling thump. The sub also made this kind of noise when my wife was using her sewing machine in an adjacent room. I made her switch outlets, and that solved the problem there.
    Have you ever heard of anything so weird? It must be a poltergeist :twisted:
    Please share similar (?) experiences, and the solution.
    Ken
  • Kevin P
    • 10812
    Maybe the sub's amplifier is sensitive to static electricity? Cat kneading or draping fabric can cause static discharges. Do you have a humidifier in your house? Humidity helps reduce static.
    • kmak
      • Dec 2002
      • 1032
      Thanks Kevin, I don't think it's dry, but what else could possibly explain this phenomena..............
      It's just that there is no physical contact between the couch and sub. I don't see a Van De Graaff generator effect going on..................
      • cbark
        • Jan 2010
        • 97
        Kevin may be on to something, moving a blanket on my couch with low lights, looks like the fourth of july. You would be suprised at the voltage levels required to do that. Also, carpet and laminate will both be the best floors for producing or adding to the static issue if that is the issue.
        It is hard to discover a problem of this type without some experimenting or knowing more about the house/room.
        It could be a wiring issue also. Your line cable runs where? Through walls, on your laminate flooring, under couch, etc.? Wiring or noise issue, if you had a problem before with the wifes sewing machine, but fix the issue then, by switching to a different circuit....? You may want to look at your house wiring.
        Does the sub have damage cables or wiring? Do you have a local surge supressor on the sub? Are the other noise producing items on the same AC circuit? Is the line cable 100ft long? Is the sub grounded or isolated? etc, etc, etc.
        Easiest solution now, would be get rid of the cat and blanket. :W
        • kmak
          • Dec 2002
          • 1032
          Don't tell Kevin.............. I'm getting rid of the cat :W
          • Kevin P
            • 10812
            Personally I'd be getting rid of the sub, wife, kids, and the mother-in-law before I'd get rid of the cat! :B But that's just me. I have 4 of the little critters and they don't make my speakers or sub crackle. Yours may be especially sensitive, and even if you got rid of the cat and the blanket, other things might still cause the problem (shuffling your feet across the carpet and then touching the sub or something near it).
            My memory could be failing me, but are you the same one who had the issue of the ceiling fan causing a pop too? Maybe something's up with your house's wiring. EDIT: Oops.. never mind, that was Jeremy. My memory is failing me. :duh:
            • dharris
              static electricity
              by dharris
              OK guys and gals, I live in a very dry climate which tends to produce tons of static electricity.
              Problem I'm having is,
              I have two dog kennels in my front room, sometimes when I get up off my couch and go to let the dogs out, the static electricity is causing my volume on my TV to go...
              03 December 2006, 14:10 Sunday
            • Karl2500
              first timer help 8-8" vs 1-15" ht sub
              by Karl2500
              Hi all thanks in advance for any help.
              OK so I am building a HT. I have a Behringer A500 amp http://www.behringer.com/A500/index.cfm?lang=eng
              that I'd like to use and I can budget about $200 for a driver or drivers. I had originally thought about using a tempest x
              http://www.d...
              11 January 2008, 01:05 Friday
            • HoustonRider
              New Rotel RSP1582 is possessed apparently
              by HoustonRider
              Hi all, new to this forum
              I recently (NOV 2015) purchased a Furman Elite 15pfi, the new Rotel RSP-1582, RMB1585 and RB1582mk2 for my dedicated HT room.
              it's all been working fine for a few weeks and now when I turn on a ceiling fan (same room) I get a very loud pop/clip...
              07 April 2016, 13:19 Thursday
            • pereze
              HT Sub issues
              by pereze
              OK, I have a Harman Kardon 12" sub (from their HTIB) that is not working. I have tried two recievers, and three different cables and nothing is coming out. The light is on, but it is not recieving signal. With that said, I feel comfortable assuming it is the sub that is having the issue. Any...
              27 November 2006, 11:41 Monday
            • srd28
              RSX-1055 sub output - troubleshooting
              by srd28
              I went to adjust the sub volume (paradigm pw2200) and there was a static spark - it was winter time and it was too dry in the basement.
              After that the sub made clicking sounds each time I went to turn on - so I lived without it for several weeks. Recently I got the sub repaired and paradigm...
              23 August 2009, 12:35 Sunday
