Can a 8 ohm rated receiver drive 6 ohm speakers?
  • AwArEnEsS
    • 151
    Also I've read an interesting article:
    "If you hear something of
    an "8 ohm amplifier", then we think usually of 8 ohm speakers.
    These are amateurs calling for help in the forums, where you are told
    something wrong about the "impedance" of the power amplifier and
    about the speakers:
    Will 4 ohm speakers work with an 8 ohm amplifier?
    4 ohm output into 8 ohm loudspeakers
    8 ohm speaker to 4 ohm channel?
    4 ohm amplifier with 2 or 8 ohm subwoofer
    Connecting 4 ohm Speakers to an 8 ohm Receiver
    4 ohm speaker on 8 ohm amp?
    8 ohm speakers - 4 ohm amp?
    Can you use 4 ohm speaker on a 8 ohm amp?
    4 ohm sub to a 6 to 8 ohm amp
    4 ohms speakers on a 8 ohms amplifier?
    Matching Speakers to Amp (4 ohm to 8 ohm)?
    Can I use 8 ohms amp to 6 ohms speakers?
    Can a 8 ohm speaker damage 6 ohm amp?
    Most loudspeaker manufacturers recommend an amplifier with power
    output equal to the speaker's "Program (Music) Power" rating or
    two times (2 ×) the "Continuous (RMS) Power" rating.
    All the questioners go out with a great determination from the fact that the
    speaker amplifier has an output impedance of 4, 6, 8 or even 16 ohms.
    Now you get a big disappointment: There are only power
    amplifiers with an output impedance of much less than 0.5 ohms.
    Accordingly, all questions are wrongly put.
    Amplifier loudspeaker ohm impedance output input voltage bridging impedance no matching speakers no matching ohms speaker conveert amp 4 - 8 - 16 resistance ohms connection of power amplifier to speakers There are no 4 ohm or 8 ohm amplifiers convert - Eberhard Sengpiel - sengpielaudio
    The universe arises from definitionless awareness.
  • AwArEnEsS
    • 151
    Also can a 6 ohms rated receiver work with 4 ohm speakers?
    Do you know not-so-expensive receivers which can drive 4 ohm speakers?
    • zakhaku
      Need advice: Amplifier for Nautilus 802
      by zakhaku
      Hello club members
      I am a newbee to the B&W fan club. I just got a pair of used Nautilus 802 for an unbelievable price. The reasons I got them were (1) They sounded awesome and (2) The price was too low to resist. There is no way I could have afforded the $4 - $5K that they actually...
      24 November 2006, 10:01 Friday
    • tannista
      can my amp drive 4 ohm speakers?
      by tannista
      Definately a noob question here, but I am trying to determine if my Nak AV8 can handle speakers rated at 4ohms, and if so how many can it handle.
      Right now I have 2 8ohm speakers attached to it, but I am considering a DIY HT project to build a new set of 4ohm main speakers (a subwoofer...
      25 July 2006, 19:20 Tuesday
    • corysmith01
      RB amps - ratings @ less than 8 ohms?
      by corysmith01
      Hi all-
      This may be a really dumb question, but I just can't seem to find the answer. I'm interested in adding an amp to my set up as I'm in the process of purchasing a pair of speakers rated at 4 ohms. My receiver, a Denon 3805, is pretty beefy, but I still feel as though the speakers'...
      15 January 2007, 20:28 Monday
    • ccorum1
      RB 1090 Too Powerful For Sonus Grand Piano Speakers?
      by ccorum1
      A great site! This is my first post, and although I have been interested in stereo gear since the 1960's, my technical knowledge is limited.
      I once owned two pair of KLH 9 Electrostatics driven by Marantz Model 9 amps, for those of you old enough to remember when you could get the ultimate...
      20 August 2003, 02:18 Wednesday
    • eclimax13
      questions about upgrading to a rotel amplifier...insight please
      by eclimax13
      hey guys..right now i have been a little disappointed with dts ma and ddthd...uncompressed pcm seems to be the only format i enjoy with my system...the other two dont seem as spacious or lively..it was suggested that i should get an external amplifier...ive been looking at the rmb 1075 and it seems...
      01 February 2009, 19:42 Sunday
