RB amps - ratings @ less than 8 ohms?
  • corysmith01
    • 51
    Hi all-
    This may be a really dumb question, but I just can't seem to find the answer. I'm interested in adding an amp to my set up as I'm in the process of purchasing a pair of speakers rated at 4 ohms. My receiver, a Denon 3805, is pretty beefy, but I still feel as though the speakers' full potential won't be realized until I add an amp. However, upon looking at the specs for Rotel amps, I can only find their 8 ohm ratings. For instance, I was looking at the RB-1050 and it says in the manual that there's a "4 ohm minimum" but there are no specs. Is this b/c the specs do not change on Rotels like on other amps? What I mean to say is, most amps I've looked at say "75 watts @ 8 ohms, 150 watts @ 4 ohms" (this is just an example). Do Rotels operate in the same manner? If so, where can I find this information? Thanks for any help. Looking forward to potentially joining the Rotel ranks. :B
  • Kevin D
    • 4601
    They do go up as the ohm load goes down. The specs aren't published as Rotel only rates them at 8ohm. The 4ohm values for most amps are out there in independent reviews and other sources.
    Here's a few from a quick search:
    1050: 100w
    1066: 75w
    1075: 200w
    1095: 330w
    Lets us know which one's you're looking at and we'll see if we can find the rating.
    Kevin D.
    • G. Martin
      • Oct 2006
      • 13
      Kevin how about the RB-1070 ?
      George
      • Kevin D
        • 4601
        RB-1070: 160w
        RMB-1048: 60w
        Kevin D.
        • corysmith01
          • 51
          Thanks for the reply! That was quick. Hmm, I wonder the rationale behind not publishing them. Oh well, at least I know they're stable down to 4 ohm. Specifically I'm looking at the 1050, and probably going no higher than the 1070...it's really just a cost issue for me as I don't have a lot of cabbage to drop. But at the same time, I feel that picking one up, regardless of the model, would help put a little more "oomph" into my speakers vs. the receiver I'm using.
          • joetama
            • 786
            Curious about the RB-1080? Kevin do you know?
            -Joe
            • Kevin D
              • 4601
              I would estimate 300w - 325w on the 1080..
              Correction on the 1095. Rotel says 300watts, a test magazine found it to be 330w.
              I found Rotel does publish some specs under the FAQ section of their website.
              Kevin D.
              • calmac
                • 110
                Just my oppinion but I wouldn't go for anything lower than a 1070 to show real improvement over the Denon's internal amps.
                Gordon
                • corysmith01
                  • 51
                  Really? I know the amps in the Denon are pretty good for a receiver as it was one of their top-flight receivers, but you don't think power from a dedicated amp would be any better? Don't get me wrong...i'm happy to not have to spend the money. :B I guess I was just concerned being that, like most receivers, this one is rated at 8 ohm with 6 being the minimum. The speakers on that are on their way are 4 ohm. Now, I do live in a small apt and nothing ever gets driven very hard lest I piss my neighbors off, so I guess I need to take that into account when considering whether I need/don't need an amp. Any thoughts? Thanks.
                  • chanlon
                    • Sep 2003
                    • 188
                    Hi.
                    I was faced with the same decision a few years ago when I was using a Rotel RSX-972 receiver with a pair of 4 ohm speakers. I added the Rotel 1075 amp. A significant difference IMO. I don't crank the amp either. However, even at low volumes, sound could be described as more punchier, lively, with greater dynamics. A dedicated amp would be an improvement.
                    • joetama
                      • 786
                      Kevin D.
                      I would believe it out of the 1080... Very solid performer if you ask me, I love mine...
                      -Joe
                        load/ohm question from guitar guy
                        by Lex
                        Jon/others, a guitar guy asked me a question, I guess because I seemed pretty knowledgable about loads and impedence. But I still want to make sure I am thinking right on this...
                        Here was his question:
                        I figure since the amp is rated at a 4 or 8 ohm load,...
                        10 September 2015, 07:18 Thursday
                      • mike c
                        RB1050 power ratings
                        by mike c
                        in the online brochure it states that the RB1050 has 50wpc
                        in the online manual it states 70wpc
                        both at 8 ohms.
                        which one is it?
                        where do you guys get the ratings for 4ohms for all the rotel amps?
                        what rating does the 1050 have on 4 ohms?
                        does it mean...
                        06 April 2006, 18:35 Thursday
                      • Ricky
                        HALO SMOKES!!! Parasound JC1 Monoblock Lab INCREDIBLE Measurements in Stereophile
                        by Ricky
                        Parasound JC1 Monblock mfg specs:
                        continuous 400W into 8 ohms and 800W into 4 ohms, short-term 1200 watts into 2 ohms; 1st 25 watts in Class A (option to reduce to 10 watts).
                        17.75W x 7.7H x 20D, 81 lbs, retail $3000 each.
                        Most amps that spec a doubling from 8 to 4 ohms...
                        13 January 2003, 22:37 Monday
                        Odyssey Amps
                        by wkhanna
                        I first became aware of the Odyssey brand over four years ago.
                        About the time I got my Rotel RB-1090 was when I was seriously looking at their power amp product line, however I never got past the point of browsing their web site before getting the Rotel (in fact, a dear friend and former...
                        24 October 2013, 15:56 Thursday
                      • Rolyasm
                        Amps? What do all the numbers mean?
                        by Rolyasm
                        Okay, I am looking at some amps for my subwoofer. I am using four 15" Avalanche drivers in a large box system. That is another forum. It has been recommended that I use Behringers's EP2500 amplifier, which I am happy to do, but wanted to compare some others and learn something at the same time....
                        15 June 2005, 12:10 Wednesday
