Is it possible to power a sub with a receiver?
  • scruffy57
    • Dec 2009
    • 3
    I have the onkyo tx-sr607. I am planning on building a subwoofer. I was wondering since I am only going to use 5.1, can I use the extra 2 channels to power a passive subwoofer? I didn't know if it was possible to use a crossover to filter out the high frequency or something.
    I am going to go ahead and apologize for my ignorance on home audio.
    thanks for your help!
  • Kal Rubinson
    • 2109
    You cannot do that as you wish. There's no way to insert the proper filters in those outputs. You would have to add an external amp for the sub.
    Kal Rubinson
    "Music in the Round"
    • ribd1
      • 8
      scruffy57....
      yes it can be done...your sub would have to have two drivers to feed one with the left amp output and the other with the right...or build two seperate subs and feed them independently...you would need a crossover to filter the high-pass...check out www.partsexpress.com you can get a basic 12db octave crossover that is pre-built, I think they only go down to 80hz...this would be fine if you are using it for hometheater. It would be ok for music, but a little high for most tastes...otherwise you'd have to build your own crossover to accomodate your needs. The only problem you may encounter is you might need to also get a passive volume control(also available from partsexpress) to balance the sub. I hope this all makes sense. Goodluck!
      • Kal Rubinson
        • 2109
        Originally posted by ribd1
        scruffy57....
        Sounds pretty kludgy and inflexible to me. Good integration of the sub will require some adjustability in level and crossover.
        Another (imho, better) approach would be to buy a plate amp, made for just this purpose.
        Kal Rubinson
        • ribd1
          • 8
          you're absolutely right...a plate amp or out-board sub amp would be much easier, flexible, and cost effective...but yes, it could be done...
          • jeffc52053
            • Apr 2009
            • 16
            Receiver
            If the Onkyo is truly a 5.1 receiver, it should have a "Sub-Out" output for a dedicated amp. That's the .1 in 5.1, RF/LF, RR/LR, center and sub.
            • terry78
              RSP-1066 and sub crossover point
              by terry78
              I purchased a RSP-1066, RMB-1075, and RDV-1080 in December and have been trying different settings with my Paradigm speakers. My dealer told me to use the 1066's 80 Hz sub crossover point and set the sub's internal crossover to 150 Hz (i.e., its max position). My sub is a Paradigm PW-2200. After a month...
              12 February 2003, 20:35 Wednesday
            • ICEMAN70
              Rotel RSX 1057 Sub Crossover Problem...
              by ICEMAN70
              Hi guy's
              I allways had my sub crossover on the Rotel RSX 1057 on 100hz. I have a large room and like little bit more bass. Recently i got a new Paradigm Servo 15 V2 to replace my old mission Sub. Anyways now i developed a Poping sound when the receiver changes settings from prologic to...
              22 August 2008, 10:52 Friday
            • neb001
              building active speakers with sub: how to do sub crossover?
              by neb001
              I plan on building a set of Zaph's B3S speakers, with integrated amp (exact model TBD, most likely a 41hz.com amp), and a sub consisting of a Tang Band W5-1138SM paired with a Dayton 70W amp. My friend that I plan on giving this to mostly uses their (completely underwhelming) current speakers for their...
              22 November 2008, 13:34 Saturday
            • augerpro
              BBV2: a small format sub/sat system
              by augerpro
              FINALLY got my BoseBuster sequel done and written up!! I've shortened the name to BBV2 so I don't get any hassle from Bose. Next I'll be finishing the Scan Disco TM and MTM, the other flavors after. My Soma Sonus site is now hosting my projects. Here is copy of that page:
              03 August 2014, 18:14 Sunday
            • JonW
              OK, lets design and build the best speaker possible (“No compromises?”)
              by JonW
              I’d like to propose a fun design exercise and see where it might end up.
              I’ve been reading some books and a lot of this web site, trying to learn about speaker design and construction. I made a sub and I’m in the middle of making the Modula MT’s. It’s all quite fun. :T And now I’m...
              02 July 2006, 18:21 Sunday
