I plan on building a set of Zaph's B3S speakers, with integrated amp (exact model TBD, most likely a 41hz.com amp), and a sub consisting of a Tang Band W5-1138SM paired with a Dayton 70W amp. My friend that I plan on giving this to mostly uses their (completely underwhelming) current speakers for their laptop, with occasional ipod use.
My question is what should I do for a sub crossover as this system will not be using a receiver of any sort? From the limited info I was able to find from searching, I'm thinking the simplest way would be to use a y split for the line out, then put a highpass filter before the speakers.
Thanks for the help! (and sorry for the long post)
