Subwoofer Timing
  • rickp15
    • Aug 2008
    • 17
    Subwoofer Timing
    Can someone explain to me the proper procedure for timing subwoofers. I have a IB in the center front (horizontal array) with FBQ and 2 subs one in each rear corner, they are running through the other channel on the FBQ. I can actually hear the delay.
    Depends on your setup. Do you have the ability to set individual distances/delays for different subs? Would depend on your receiver/processor, as well as whatever else you have in the subwoofer path along the way.
    We discussed this issue this past week in another thread here about 7.2/9.2 receivers.
    • rickp15
      • Aug 2008
      • 17
      Problem solved, I ran the rear sub line through a DCX channel I wasn't using then on to the FBQ, cranked in about 7.?ms of delay and whala tight bass, NICE!
      • kgveteran
        Using TrueRta to adjust subwoofer delay
        by kgveteran
        How would I adjust the delay for my subs on my processor to match the mains of my HT ? There has been talk of this on other forums.
        Most of the talk is that there is a problem with the subwoofer delay and that the numbers don't coinside.Your thoughts.
        20 February 2006, 20:15 Monday
      • ro9397
        Sub: sonotube, siting, EQ, delay?
        by ro9397
        Questions concern siting & enclosure material for a custom sub for a very high-end music reproduction system. Sub source is a mono signal from a proprietary pure-analog processor. Will start w/ one sub; depending on results may add a second sub.
        Room Dimensions & Volume
        03 February 2007, 01:28 Saturday
        How many subs is enough?
        by Andrew Pratt
        How Many Subwoofers Is Enough?
        Floyd Toole and Todd Welti may surprise you with their answer.
        In previous columns on subwoofer placement, we’ve discussed the conventional wisdom of adding the ".1" to 5.1-, 6.1-, and 7.1-channel surround sound. That wisdom pretty...
        02 November 2004, 14:25 Tuesday
      • Dmantis
        M&K MX-125 Mark II Subwoofer
        by Dmantis
        What's up everyone?
        I recently aquired a used M&K sub woofer. It had a bad Phase switch which was causing it to pop. The person I got it from didn't want to get it fixed and decided to get a new woofer.
        I took this subwoofer home, fixed the Switch and decided to add it into my system...
        16 November 2013, 07:50 Saturday
      • Chris CRt
        Parasound C1 Settings with THX Subs
        by Chris CRt
        Hello!
        I have a random question here. I have a pair of M&K MX-350 THX Ultra subwoofers that I am hooking up to my Parasound Halo C1 unit. Right now, I have the sub out going to one of the subs and the other sub hooked up to Pro 2.
        Under "Size Setup", I am...
        06 November 2004, 15:39 Saturday
